Home > Maintenance & Mods (L322) > Gearbox Specialist local to Mansfield Notts
michele5041
United Kingdom 2003 Range Rover HSE 4.4 V8 Baltic Blue
Well I had my gearbox and Torque Converter refurbed 3 1/2 years ago just under 30k miles covered, and I'm now getting the same torque converter symptoms. Anyone recommend a quality gearbox specialist in and around the Mansfield area. I don't want to send it back to the one I originally used if it's only going to last 3 1/2 years.
Just spent a shedload changing the wheels, calipers, discs & pads. Sat Nav, TV module re-soldered. History - Glutton for Punishment
Mazda RX8 - Current
Alfa GTV 2.0L Twin Spark
Jeep Cherokee 2.5td
BMW 318SI
Ford Mondeo ST24
Ford Mondeo Ghia X
Fiat Mirafiori 131 TC
Austin Allegro 1750hl
Post #428212 18th Feb 2017 8:44am
I would be talking to RRPhil
TBH I can never remember which unit is which & whether you have one that he would do, but if not, he may be able to point you in the right direction Thumbs Up
Post #428213 18th Feb 2017 8:50am
Weegie
OP should have ZF5HP24 gearbox which RRPhil does. +1 on Alistair's recommendation. John
GAP iiD BT
Post #428215 18th Feb 2017 8:56am
Yep, would be a job for Phil. 5hp24 transmissions Ltd.
http://www.fullfatrr.com/forum/topic38676.html There is nothing that can't be fixed with a hammer😜😜
Post #428216 18th Feb 2017 8:56am
RRPhil
To be honest, I’d be wary about having a torque converter re-manufactured for a second time. Both the main impeller casing and the LUC reaction plate have to have the old welds turned off and then are re-welded back into position. New converters aren’t cheap, I’m afraid. The last brand new F38 TC that I sold was for £550 and it’s around a 5 hour job to get the transmission out and back in again to replace it (though no specialist transmission knowledge is needed for this, so you could use any competent mechanic who you trust).
It may be possible to pick up a second-hand converter off eBay, or wherever (usually for around £75-£125) and then have it re-manufactured (£240) which would work out slightly cheaper – assuming it hadn’t been re-manufacture before, of course. 11 litres of LT71141 fluid & a new Filtran filter would add a further £145. Overall you’re probably looking at £1000 to do the job properly which, I guess, is why people usually get the transmission overhauled too while it’s out of the vehicle.
Phil
Post #428486 20th Feb 2017 10:35am
