Home > In Car Electronics (L405) > SDD module programming |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
Sdd needs an internet connection. That's the proper up to date official version. There are offline older versions that may be able to do certain things but may do more damage to the car than good, being out of date. The sdd will look at the original as built file online against the car it's connected to and see if there is any updates that need to be applied.
28th Jan 2017 12:48am |
steveball Member Since: 09 Jun 2011 Location: Corsham, UK Posts: 208 |
There is a cunning mechanism to download the modules that are required, presumably designed for workshops without wifi coverage.
28th Jan 2017 7:42am |
andy2577 Member Since: 04 Jun 2016 Location: Liverpool Posts: 64 |
basically i had a customer ring me up and ask me if i could code certain modules to the vin such as engine ecu and gearbox ecu
28th Jan 2017 8:52am |
any idea what its called ? 2002 - Blue L322 3.0 TD Vogue (Previous) 2006 - Black L322 4.4 V8 Vogue Autobiography (Previous) 2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present) 2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present) |
