Home > In Car Electronics (L405) > SDD module programming
andy2577
United Kingdom 2014 Range Rover Autobiography TDV6 Santorini Black
Does anyone know if you need the internet to be able to program modules or can it be done without the internet ? wasnt sure if you needed to download payloads or not ?
ive not got a car i can try it on hence for the question Thumbs Up 2002 - Blue L322 3.0 TD Vogue (Previous)
2006 - Black L322 4.4 V8 Vogue Autobiography (Previous)
2014 - Black L405 3.0 TDV6 Vogue Autobiography (Present)
Post #425008 27th Jan 2017 8:17am
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Sdd needs an internet connection. That's the proper up to date official version. There are offline older versions that may be able to do certain things but may do more damage to the car than good, being out of date. The sdd will look at the original as built file online against the car it's connected to and see if there is any updates that need to be applied.
As for adding extra modules that weren't on the car when it was built, you may need a tool like iid or faultmate msv or similar to activate them so they work and are recognised by the car.
You may need the newer version of sdd which is called pathfinder.
What are you trying to do?
Post #425139 28th Jan 2017 12:48am
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
There is a cunning mechanism to download the modules that are required, presumably designed for workshops without wifi coverage.
SDD determines what modules are present and if all modules are not present, prompts for a USB stick onto which it writes a small application and som config files. You then take that stick to a Windows PC with Internet access and run the application, which downloads the necessary files and writes them back to the memory stick. Return that to the machine running SDD and the necessary files will be copied across.
All quite straightforward really. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #425145 28th Jan 2017 7:42am
andy2577
basically i had a customer ring me up and ask me if i could code certain modules to the vin such as engine ecu and gearbox ecu
he has asked his local dealer but due to their workload they have said they wouldnt be able to look at it till mid March ?! 2002 - Blue L322 3.0 TD Vogue (Previous)
Post #425165 28th Jan 2017 8:52am
andy2577
any idea what its called ? 2002 - Blue L322 3.0 TD Vogue (Previous)
Post #425166 28th Jan 2017 8:52am
