Home > Technical (L322) > A few Questions regarding my L322 Td6
Paul1234002
England 2006 Range Rover Vogue 4.4 V8 Barolo Black
I have fitted a new EGR Valve December 2016 and when i turned the engine over there was a droning sound resonating down what seems to be the exhaust. Is this right? Is there something I have missed. This happens now every time i start the car.
The car is regularly serviced it has only done 3500 miles in the last year. However it seems to down on power. Although when in sport mode it moves.
Is there any thing i can do or is it a dealer job.
Any help would be really appreciated. I have even thought of having the car Remapped - Should i or Not.
Post #424224 22nd Jan 2017 12:06pm
Weegie
Might be the Fuel Burning Heater kicking in when you start up? The FBH was standard on the TD6. John
GAP iiD BT
Post #424233 22nd Jan 2017 12:30pm
Paul1234002
Thanks for the reply.
The noise only happened after the new EGR was fitted. Does that make sense?
Post #424237 22nd Jan 2017 12:48pm
Weegie
Wouldn't seem to be the FBH then. Are you sure all the connections for the EGR are in place and tight? John
GAP iiD BT
Post #424238 22nd Jan 2017 12:54pm
Paul1234002
Yes it was only four bolts to the inlet Manifold and to Jubilee Clips and all tight
Post #424239 22nd Jan 2017 1:00pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I would have blanked the egr off, i did mine and was sure better plus no dirty recycled gases going back in the engine, i used a pro bitz tuning box as well and it flew no lag and better economy by a few miles Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #424317 22nd Jan 2017 7:53pm
mjdronfield
I blanked mine off when I had a td6.... never had an issue and much better......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #424340 22nd Jan 2017 9:26pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I think blanking off the EGR will help the turbo to live longer too, as the variable vanes won't gunge up so easily.
Post #424345 22nd Jan 2017 10:06pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Did you blank the vacuum pipe off ?.
Post #424371 23rd Jan 2017 6:51am
Paul1234002
Blanking the EGR. Did this not throw any faults?
Post #424373 23rd Jan 2017 7:41am
Scottyav
yes _____________________________________________________
Post #424381 23rd Jan 2017 9:08am
Scottyav
nope it doesnt _____________________________________________________
Post #424382 23rd Jan 2017 9:08am
Paul1234002
Gentlemen,
I would like to thank you for your suggestions. Update.
Blanked the EGR and plugged the vacuum pipe and i have to say it has transformed the car. It has got its pulling power back.
Thanks again for all your help.
Post #424576 24th Jan 2017 3:02pm
gregdav
Post #424612 24th Jan 2017 6:51pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
I assume that's on the Vogue and above models and not on all the TD6 models?
Post #424622 24th Jan 2017 7:07pm
