Home > Technical (L322) > A few Questions regarding my L322 Td6 |
Paul1234002 Member Since: 06 Oct 2015 Location: Manchester Posts: 32 |
I have fitted a new EGR Valve December 2016 and when i turned the engine over there was a droning sound resonating down what seems to be the exhaust. Is this right? Is there something I have missed. This happens now every time i start the car.
22nd Jan 2017 12:06pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Might be the Fuel Burning Heater kicking in when you start up? The FBH was standard on the TD6. John
22nd Jan 2017 12:30pm |
Thanks for the reply.
22nd Jan 2017 12:48pm |
Wouldn't seem to be the FBH then. Are you sure all the connections for the EGR are in place and tight? John
22nd Jan 2017 12:54pm |
Yes it was only four bolts to the inlet Manifold and to Jubilee Clips and all tight |
22nd Jan 2017 1:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
I blanked mine off when I had a td6.... never had an issue and much better......
22nd Jan 2017 9:26pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I think blanking off the EGR will help the turbo to live longer too, as the variable vanes won't gunge up so easily. |
22nd Jan 2017 10:06pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Did you blank the vacuum pipe off ?. |
23rd Jan 2017 6:51am |
Blanking the EGR. Did this not throw any faults? |
23rd Jan 2017 7:41am |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 |
yes _____________________________________________________ Zambezi silver Vogue Se unique |
23rd Jan 2017 9:08am |
nope it doesnt _____________________________________________________ Zambezi silver Vogue Se unique |
Gentlemen,
24th Jan 2017 3:02pm |
24th Jan 2017 6:51pm |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I assume that's on the Vogue and above models and not on all the TD6 models? |
24th Jan 2017 7:07pm |
