Home > Technical (L322) > Judder when braking |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
Couple of years ago I had a similar issue. Mine had decent pads but I fitted LR genuine and the judder vanished.
18th Jan 2017 4:48pm |
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 |
Hmm, |
18th Jan 2017 4:55pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7941 |
Could be pads - could be a sticky caliper, or could be flange / hub causing the disk to not rotate completely true - or could be something else entirely..... |
18th Jan 2017 5:13pm |
I was thinking, bushes, ball joints etc but will take the discs off again to be really sure they are seated flat as a very flat thing, any other thoughts? |
18th Jan 2017 5:21pm |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 |
Brake judder at what speed or is it the same whatever speed you're braking at? 2009 Vogue TDV8 Nara Bronze
18th Jan 2017 6:12pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
did you check the rears? cant be wrong to look there, if only as prevention/rule out/safety. |
18th Jan 2017 7:01pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 385 |
Sounds like rotors might be warped. |
19th Jan 2017 2:00am |
It's not really noticeable at less than 45 mph and most noticable above 55 but only when braking gently/moderately. |
19th Jan 2017 8:23am |
Discs are what we Brits call rotors, see post 1 |
19th Jan 2017 8:24am |
Good point, will check at the indie with a run-out gauge, but not hopeful as it feels like front. |
19th Jan 2017 8:26am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd check the fronts are running true at the same time... I had a warped new disc... It was a Britpart drilled a slotted one
19th Jan 2017 9:03am |
Miggit, I take that on board, but, the old ones where replaced because of pulsing, so doesn't this point to something else, bearings etc? |
19th Jan 2017 9:18am |
By the way, did you notice that the new "rotors" where much noisier than plain discs? |
19th Jan 2017 9:21am |
Err sort of only under heavy braking But it's a small price to pay for the stopping power that they offer Yesterday I couldn't spell Engineer... Today I are one!
19th Jan 2017 9:35am |
