![]() | Home > Technical (L322) > Judder when braking |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Couple of years ago I had a similar issue. Mine had decent pads but I fitted LR genuine and the judder vanished.
DavidS Member Since: 23 Jul 2014 Location: Valencia region Posts: 73 ![]() ![]() ![]() |
Hmm, |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Could be pads - could be a sticky caliper, or could be flange / hub causing the disk to not rotate completely true - or could be something else entirely..... |
I was thinking, bushes, ball joints etc but will take the discs off again to be really sure they are seated flat as a very flat thing, any other thoughts? |
Rich86 Member Since: 10 Mar 2013 Location: Surrey Posts: 509 ![]() ![]() ![]() |
Brake judder at what speed or is it the same whatever speed you're braking at? 2009 Vogue TDV8 Nara Bronze
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
did you check the rears? cant be wrong to look there, if only as prevention/rule out/safety. |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 387 ![]() ![]() |
Sounds like rotors might be warped. |
It's not really noticeable at less than 45 mph and most noticable above 55 but only when braking gently/moderately. |
Discs are what we Brits call rotors, see post 1 ![]() |
Good point, will check at the indie with a run-out gauge, but not hopeful as it feels like front. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Miggit, I take that on board, but, the old ones where replaced because of pulsing, so doesn't this point to something else, bearings etc? |
By the way, did you notice that the new "rotors" where much noisier than plain discs? |
Err sort of |
