Home > Technical (L322) > Does the 2011MY FFRRV have self levelling headlights? |
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 |
I recently had significant repairs carried out to my FFRR which included 2 new headlights. Since then it has passed an MOT but on dip the lights seem to be ever so slightly higher than I remember them being before the repairs, resulting in me being flashed quite often by annoyed motorists at night, especially when driving up hill.
10th Jan 2017 7:24pm |
This link would suggest that I do (should) indeed have self levelling headlights.
10th Jan 2017 7:39pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Yes. |
10th Jan 2017 8:06pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 488 |
they should be slef leveling but you still have to manually set the height they start at, if you look behind the lights there is a plastic adjusting lug sticking up with the philips screw head. use that to adjust the datum height. Cheers
10th Jan 2017 9:12pm |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
drove the RR the first time in the dark tonight and got a few flashes from drivers. Checked the level when got home against the garage door and it was high.
10th Jan 2017 9:27pm |
Just a note for future reference. All cars with HID headlights must have auto levelling by law. They must also have a cleaning system (washers or wipers or both) |
11th Jan 2017 9:45am |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I thought self leveling was applied by the air suspension rendering anything additional on the headlamps superfluous.
11th Jan 2017 10:08am |
The servos on the L322 lamps are much quicker to respond when driving. As the car rides over undulations in the road the servos react to signals supplied from the air suspension. I don't recall the P38 having HID lamps although I could be wrong on that. |
11th Jan 2017 10:12am |
I popped into the repairers this morning and they confirmed that the headlamp self leveling control module isn't communicating with the suspension control module and so isn't moving the headlights as it should. So problem identified but needs the LR super computer to correct it. A job for next week then. 4.4 TDV8 Vogue Baltic Blue MY11 |
11th Jan 2017 2:31pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Actually, all cars fitted from new with HID headlights must have auto levelling and cleaning to obtain type approval There are no such rules for after-market HID |
11th Jan 2017 3:15pm |
Well it turns out that my RRV HID headlights do not have self leveling motors in them at all but rely on the self levelling suspension to comply with the law. Aparently only the adaptive higher spec lights have motors in them for looking round corners.
18th Jan 2017 4:34pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35263 |
didnt know that |
18th Jan 2017 4:40pm |
The adaptives are also meant to adjust their level during hard acceleration and hard braking. |
19th Jan 2017 7:01am |
