Home > Technical (L322) > Does the 2011MY FFRRV have self levelling headlights?
Baron
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
I recently had significant repairs carried out to my FFRR which included 2 new headlights. Since then it has passed an MOT but on dip the lights seem to be ever so slightly higher than I remember them being before the repairs, resulting in me being flashed quite often by annoyed motorists at night, especially when driving up hill.
I'm wondering if the repairer may not have correctly/completely connected them up but I'm not sure they have self levelling motors in them. Can anyone please advise? Maybe I just need to adjust them down a bit.
Thanks. 4.4 TDV8 Vogue Baltic Blue MY11
Post #422113 10th Jan 2017 8:24pm
Baron
This link would suggest that I do (should) indeed have self levelling headlights.
http://workshop-manuals.com/landrover/l322...mps_only)/ 4.4 TDV8 Vogue Baltic Blue MY11
Post #422121 10th Jan 2017 8:39pm
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
I get flashed sometimes as the lights are adapative and sometimes don't change from full beam to dipped so I've changed the settings to switch off the adaptive setting.
Not sure about the self levelling aspect but someone on here will know. 2009 Vogue TDV8 Nara Bronze
2002 Vogue V8 Zambezi Silver
1986 90 Pick up Deep Bronze Green
1978 Series III SWB Deep Bronze Green
Post #422123 10th Jan 2017 8:48pm
GraemeS
Australia
Re: Does the 2011MY FFRRV have self levelling headlights?
Yes.
Post #422126 10th Jan 2017 9:06pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
they should be slef leveling but you still have to manually set the height they start at, if you look behind the lights there is a plastic adjusting lug sticking up with the philips screw head. use that to adjust the datum height. Cheers
James
Post #422135 10th Jan 2017 10:12pm
proser
drove the RR the first time in the dark tonight and got a few flashes from drivers. Checked the level when got home against the garage door and it was high.
Out with an 6mm (I think) allen key and adjusted them down to just below level.
the adjuster is the one more to the centre of the car on each light. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #422136 10th Jan 2017 10:27pm
mzplcg
Just a note for future reference. All cars with HID headlights must have auto levelling by law. They must also have a cleaning system (washers or wipers or both)
Post #422162 11th Jan 2017 10:45am
kooky_guy
I thought self leveling was applied by the air suspension rendering anything additional on the headlamps superfluous.
That certainly seems to be the cased on the P38s. 2010 4.4 TDV8 Vogue SE
Post #422169 11th Jan 2017 11:08am
mzplcg
The servos on the L322 lamps are much quicker to respond when driving. As the car rides over undulations in the road the servos react to signals supplied from the air suspension. I don't recall the P38 having HID lamps although I could be wrong on that.
Post #422170 11th Jan 2017 11:12am
Baron
I popped into the repairers this morning and they confirmed that the headlamp self leveling control module isn't communicating with the suspension control module and so isn't moving the headlights as it should. So problem identified but needs the LR super computer to correct it. A job for next week then. 4.4 TDV8 Vogue Baltic Blue MY11
Post #422200 11th Jan 2017 3:31pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Actually, all cars fitted from new with HID headlights must have auto levelling and cleaning to obtain type approval
There are no such rules for after-market HID
Post #422201 11th Jan 2017 4:15pm
Baron
Well it turns out that my RRV HID headlights do not have self leveling motors in them at all but rely on the self levelling suspension to comply with the law. Aparently only the adaptive higher spec lights have motors in them for looking round corners.
You learn something every day. 4.4 TDV8 Vogue Baltic Blue MY11
Post #423516 18th Jan 2017 5:34pm
didnt know that Thumbs Up
Post #423518 18th Jan 2017 5:40pm
GraemeS
Australia
The adaptives are also meant to adjust their level during hard acceleration and hard braking.
Post #423643 19th Jan 2017 8:01am
