Home > Technical (L322) > All The Amigos |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 186 |
Garage (Guy Salmon) first though it was a wiring fault, then the HP fuel pump. They've still not diagnosed it, after 8 working days....... 17 MY Corris Grey 4.4 VAB
14th Jan 2017 7:08pm |
forrey Member Since: 24 Jan 2016 Location: alberta Posts: 24 |
is that guy slam on in croydon ? if it is take it somewhere else ! they are stupid monkey ,they had a disco 2 of mine for a week and still could not work it out ..in the end was a loose alternator wire ... and the then left a spanner in the engine bay and luckily it never got stuck in anything...bottom line go to guildford instead..they are much better |
14th Jan 2017 8:51pm |
Bristol......day 9 starts tomorrow...... 17 MY Corris Grey 4.4 VAB
15th Jan 2017 5:25pm |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
When you get a whole bunch of warnings all at once, my guesses would be: battery, alternator, Mechanic didn't hook something back up or reset something from last time. |
15th Jan 2017 8:18pm |
HP fuel pump apparently. c£2300 to fix but possibly £7000 for a wider fix (awaiting the explanation anout that - seems to be relatrd to doing more than flushing). Found metal particles in fuel filter. Does this sound right? Also, given the in-tank pump failed 6 weeks ago, are they linked? 17 MY Corris Grey 4.4 VAB
18th Jan 2017 12:10pm |
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 |
Sounds like pump and injectors may need replacing which could explain the costs Alex
18th Jan 2017 1:18pm |
The failed in-tank pump up the HP pump. To be sure of removing all bits from the system its the expensive option. Means rebuild of HP fuel side using new components. Bloody thing had better work well from now on. 17 MY Corris Grey 4.4 VAB
19th Jan 2017 5:26pm |
