![]() | Home > Technical (L322) > All The Amigos |
Triarii Member Since: 10 Feb 2015 Location: Wess Vinglun Posts: 187 ![]() ![]() ![]() |
Garage (Guy Salmon) first though it was a wiring fault, then the HP fuel pump. They've still not diagnosed it, after 8 working days....... |
forrey Member Since: 24 Jan 2016 Location: alberta Posts: 24 ![]() ![]() ![]() |
is that guy slam on in croydon ? if it is take it somewhere else ! they are stupid monkey |
Bristol......day 9 starts tomorrow...... |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
When you get a whole bunch of warnings all at once, my guesses would be: battery, alternator, Mechanic didn't hook something back up or reset something from last time. |
HP fuel pump apparently. c£2300 to fix but possibly £7000 for a wider fix (awaiting the explanation anout that - seems to be relatrd to doing more than flushing). Found metal particles in fuel filter. Does this sound right? Also, given the in-tank pump failed 6 weeks ago, are they linked? 17 MY Corris Grey 4.4 VAB
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Sounds like pump and injectors may need replacing which could explain the costs Alex
The failed in-tank pump |
