Home > Maintenance & Mods (L322) > battery drain
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
tried the parasitic drain tests yesterday ,no chance even though i fooled the interior lights in to thinking the door was closed the alarm started beeping Censored
Post #420130 30th Dec 2016 10:17am
Have you tried charging the battery up fully and then disconnecting the battery -ve terminal and then leaving the car overnight?
Post #420134 30th Dec 2016 10:50am
vmaxer
right i spent all yesterday checking all sorts of things Confused the one thing i did,nt understand is the fan noise when you unlock car ,so did some tinternetin and found it to be fuel burning heater fan Rolling Eyes now im confused ,from what i understand you havto have this thing switched on with diagnostics i have aux heating on my screen but its not set on any time so why does the fan come on when you unlock car and how do you check if its working by the way after 30 mins meter showed no amp drain from battery Whistle
Post #420902 3rd Jan 2017 9:55am
miggit
FBH is std on TD6 Thumbs Up
Sounds like there maybe an issue with the configuration.. might be time to read the hand book Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #421058 3rd Jan 2017 11:22pm
vmaxer
if only i had the hand book Big Cry
Post #421089 4th Jan 2017 10:12am
proser
goto https://topix.landrover.jlrext.com register and then put your VIN number in. click on documents on the right and then it will give you an online copy of your handbook to browse on the left. Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #421090 4th Jan 2017 10:14am
vmaxer
thanks mark Thumbs Up
Post #421114 4th Jan 2017 1:02pm
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
had this issue on my fullfat I though it was the final stage resistor. but was not. locked the car and checked to see if the red lights turned off. they did.
ended up buying a new battery and guess what. Thumbs Up
Post #421514 6th Jan 2017 8:52pm
nar53
France 2002 Range Rover Vogue Td6 Giverny Green
[quote="miggit"]FBH is std on TD6 Thumbs Up
Forgive my ignorance but how do I identify the FBH?
Mines a 2002 TD6
Post #421532 7th Jan 2017 1:03am
vmaxer
its under the battery tray if you have one fitted Thumbs Up
Post #421626 7th Jan 2017 4:01pm
nar53
Thanks vmaxer, I don't think it has one but miggit suggests that all TD6's have them.
Anyway I'll take a look next time lift the lid
Cheers....
Post #421629 7th Jan 2017 4:18pm
miggit
The FBH was std on diesel cars, if you don't have one then it has been removed, rather than not fitted Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #421689 7th Jan 2017 11:25pm
How loud is the fan ? when you unlock your car and open the door you will always hear a fan that cools the ECU's just ahead of the front bulkhead behind the battery by drawing in air from the cabin. 2008 MY Supercharged
Post #421695 8th Jan 2017 1:09am
vmaxer
new battery and all good Very Happy i dont think the fbh is working so the fan noise must be the ecu cooler as no fumes under wheel arch or pipes getting warm Crying or Very sad but around 3 to 5 seconds for glowplug light to go out so im happy with that Thumbs Up i may just have a mess with the fbh when it gets warmer Whistle
Post #423472 18th Jan 2017 11:05am
miggit
Whistle You wont need it then Laughing
I gave mine a run today... realised that the last time the engine had turned was Christmas day Embarassed But it started without any worries Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #423597 18th Jan 2017 9:17pm
