Did a trial fittment of my new lights. Wanted to see how they looked but I've not wired in the resistors or ballasts. Anyway for some reason the indicators flashing normal speed and fog lights working as it should. Only issue is the check rear light message on dash.. looks like I won't need to do the fog light fix..
does the dash error message go when I add resistors or will the iid tool help if I disable cold monitoring? Would love to simply fix it with my iid tool ..I've also noticed the upper left led is faulty or is this due to not having resistor/ballasts..ta
