Home > In Car Electronics (L322) > Possible earth fault???
spykemike
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
Advice please folk (bit long winded but you'll need the history)
Got in the car yesterday morning and the radio didn't come on. This isn't unusual as it's got a mind of its own, re-started the car and the radio head came on but all the graphics had changed?? Drove to Manchester parked up and returned to car 4 hours later to find a strange buzzing coming from the dashboard and the faintest air bag light on, Inserted key, nothing!
Ignition module and steering lock wouldn't engage and I had a dead L322 (still buzzing away!). Called RAC out and the technician was of the opinion that it was an earth fault somewhere. He connected the volt meter and it had dropped to 11.6v. He also tried putting some juice in and that made no difference. As an added extra my L322 has an electrical isolator fitted, we shut everything down and turned it back on but this made no difference. Cars now been taken on low loader to garage awaiting investigation on Monday
Any clues from our resident experts please as to whether you believe he''s right and has anyone come across this issue before??
PS. New ignition module was fitted a few months ago Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418388 18th Dec 2016 3:17am
i'd start with a brand new fully charged battery... ... - .- -.
Post #418403 18th Dec 2016 8:56am
Lot of earth terminals, I would start as Stan says at the battery end of the car. Fully charged battery wth the terminals checked for tightness. With a good connection there and plenty power, if that hasn't sorted it then it will make fining he problem a whole lot easier.
Buzzing from dash could be something heating related which is causing the drain? Possibly FSR, as this can be the source of battery drain if it has failed. There is nothing that can't be fixed with a hammer😜😜
Post #418429 18th Dec 2016 10:25am
I agree with Stan, new fully charged battery should get the car started. I doubt you have an earth fault as such but would suggest checking the radio, satnav ans dsp units for a problem causing current drain. Check for water damage to these bits which could cause current drain. When you get the car going you could try removing fuse 49 and see if things improve.
Post #418431 18th Dec 2016 10:49am
spykemike
Thanks for the advice I'll start with a full battery in the morning Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418551 18th Dec 2016 9:20pm
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The graphics changing could be the sat nav going down. The radio seems to have a very basic screen so it will keep working if there is a dead nav in the system. The screen looks very 80's though!
Found this out trying to get my new mk4 nav to boot properly, thankfully fixed now!
Post #418605 19th Dec 2016 9:05am
spykemike
Yep that's the one!
We've come to the conclusion that it's the ignition ecu not getting the signal to the steering lock ecu. It's working very intermittently but we have got it started Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418615 19th Dec 2016 10:02am
Weegie
A thought for you. I had a similar experience which was caused by dropping the key onto a hard surface. It dislodged the interior and the buttons were not making contact every the time.
May not be relevant but easy to check that the buttons are working correctly. It also dislodged the transponder (the small black piece inside they key) at the same time. John
GAP iiD BT
Post #418619 19th Dec 2016 10:23am
spykemike
Keys
Thanks, we tried the spare key but had the same fault mate Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418905 20th Dec 2016 9:37pm
spykemike
Still having problems
Update, it was taken to a LR specialist today and they thought they fixed it, got in and nothing then after several attempts we had lift off, still puzzled I took the key out of the ignition to find the brake lights on. Put key back in and they went off, i'm now thinking that the LCM is at fault - back to the LR 'specialists' in the morning, that's if it starts!
Any ideas guys?????? Big Cry Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418906 20th Dec 2016 9:41pm
the lcm behind the bonnet pull lever sometimes gets wet or fails causing the brake light on problem.. ... - .- -.
Post #418910 20th Dec 2016 9:56pm
spykemike
Thanks Stan, its going to be the first port of call in the morning Thumbs Up Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418911 20th Dec 2016 9:58pm
spykemike
Would the lcm failing cause issues with the ignition????? Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418912 20th Dec 2016 9:59pm
miggit
Any ecu / module going down on the canbus can cause havoc through out the car.... I had a drowned DSP amp, effected the central locking, display, and a whole load of other things Shocked
FYI "Earth fault" is technical recovery talk for I haven't got a clue, but I don't want the office / punter to know Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #418972 21st Dec 2016 10:39am
spykemike
Laughing Laughing Laughing yep that was the top and bottom of it. It's back with the experts now let's see what they come up with 🙈 Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that!
Post #418978 21st Dec 2016 11:14am
