Home > In Car Electronics (L322) > Possible earth fault??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35270 |
i'd start with a brand new fully charged battery... ... - .- -.
18th Dec 2016 8:56am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Lot of earth terminals, I would start as Stan says at the battery end of the car. Fully charged battery wth the terminals checked for tightness. With a good connection there and plenty power, if that hasn't sorted it then it will make fining he problem a whole lot easier.
18th Dec 2016 10:25am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
I agree with Stan, new fully charged battery should get the car started. I doubt you have an earth fault as such but would suggest checking the radio, satnav ans dsp units for a problem causing current drain. Check for water damage to these bits which could cause current drain. When you get the car going you could try removing fuse 49 and see if things improve. |
18th Dec 2016 10:49am |
spykemike Member Since: 31 Dec 2015 Location: Preston Posts: 13 |
Thanks for the advice I'll start with a full battery in the morning Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
18th Dec 2016 9:20pm |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 |
The graphics changing could be the sat nav going down. The radio seems to have a very basic screen so it will keep working if there is a dead nav in the system. The screen looks very 80's though!
19th Dec 2016 9:05am |
Yep that's the one!
19th Dec 2016 10:02am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
A thought for you. I had a similar experience which was caused by dropping the key onto a hard surface. It dislodged the interior and the buttons were not making contact every the time.
19th Dec 2016 10:23am |
Thanks, we tried the spare key but had the same fault mate Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
20th Dec 2016 9:37pm |
Update, it was taken to a LR specialist today and they thought they fixed it, got in and nothing then after several attempts we had lift off, still puzzled I took the key out of the ignition to find the brake lights on. Put key back in and they went off, i'm now thinking that the LCM is at fault - back to the LR 'specialists' in the morning, that's if it starts!
20th Dec 2016 9:41pm |
the lcm behind the bonnet pull lever sometimes gets wet or fails causing the brake light on problem.. ... - .- -.
20th Dec 2016 9:56pm |
Thanks Stan, its going to be the first port of call in the morning Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
20th Dec 2016 9:58pm |
Would the lcm failing cause issues with the ignition????? Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
20th Dec 2016 9:59pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Any ecu / module going down on the canbus can cause havoc through out the car.... I had a drowned DSP amp, effected the central locking, display, and a whole load of other things
21st Dec 2016 10:39am |
yep that was the top and bottom of it. It's back with the experts now let's see what they come up with 🙈 Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
21st Dec 2016 11:14am |
