![]() | Home > In Car Electronics (L322) > Possible earth fault??? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35606 ![]() ![]() |
i'd start with a brand new fully charged battery... ... - .- -.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8744 ![]() ![]() ![]() |
Lot of earth terminals, I would start as Stan says at the battery end of the car. Fully charged battery wth the terminals checked for tightness. With a good connection there and plenty power, if that hasn't sorted it then it will make fining he problem a whole lot easier.
I agree with Stan, new fully charged battery should get the car started. I doubt you have an earth fault as such but would suggest checking the radio, satnav ans dsp units for a problem causing current drain. Check for water damage to these bits which could cause current drain. When you get the car going you could try removing fuse 49 and see if things improve. |
spykemike Member Since: 31 Dec 2015 Location: Preston Posts: 13 ![]() ![]() ![]() |
Thanks for the advice I'll start with a full battery in the morning Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
ndg Member Since: 25 Mar 2016 Location: Warwickshire Posts: 94 ![]() ![]() ![]() |
The graphics changing could be the sat nav going down. The radio seems to have a very basic screen so it will keep working if there is a dead nav in the system. The screen looks very 80's though!
Yep that's the one!
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3254 ![]() ![]() ![]() |
A thought for you. I had a similar experience which was caused by dropping the key onto a hard surface. It dislodged the interior and the buttons were not making contact every the time.
Thanks, we tried the spare key but had the same fault mate Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
Update, it was taken to a LR specialist today and they thought they fixed it, got in and nothing then after several attempts we had lift off, still puzzled I took the key out of the ignition to find the brake lights on. Put key back in and they went off, i'm now thinking that the LCM is at fault - back to the LR 'specialists' in the morning, that's if it starts!
the lcm behind the bonnet pull lever sometimes gets wet or fails causing the brake light on problem.. ... - .- -.
Thanks Stan, its going to be the first port of call in the morning |
Would the lcm failing cause issues with the ignition????? Was looking forward to a stress free retirement, then I went and bought a FFRR, and that they say is that! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Any ecu / module going down on the canbus can cause havoc through out the car.... I had a drowned DSP amp, effected the central locking, display, and a whole load of other things |
