Home > Maintenance & Mods (L322) > Seat Foam Replacement
dan_uk_1984
I was thinking of replacing the foam in my drivers seat as the side has collapsed just slightly. I thought this was going to be a super expensive part...
The whole seat base is only £37.38 according to Britpart, and not much different from LR. Bargain much:
http://www.brit-car.co.uk/product.php?xProd=119548
Post #42246 13th Dec 2010 11:14pm
surprisingly its not that hard to strip the seat, my son replaced the occupancy sensor in my passenger seat and it went quite smoothly.... ... - .- -.
Post #42261 14th Dec 2010 9:10am
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Dan
Dimensions: 1cm x 53cm x 57cm ???
Which foam should that be? 1cm thick !
If the item lays on your kitchen table, please show us a pic!
Think, that this will be only the last layer and wonder, if there is any diolen fill between foam and leather... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #42276 14th Dec 2010 1:20pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Stan, is there any chance of a write up on how to replace the foam / sensors? I'm curious to know how to get the seat cover off so I can put a new foam in.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #185348 28th Apr 2013 8:03pm
ahebron
New Zealand
Perfect timing. I have been thinking about getting my car into an upholsterer to get them to rebuild the seat. But thanks to dan_uk_1984 I have now ordered a new squab foam.
All we need now is as the TheAllSeeingPie mentioned is a writeup or better still a Wiki.
Adrian VW Amarok 2014 Highline auto
Post #185381 29th Apr 2013 7:08am
crikey this was back in 2010 and as said my son done it..i recall that the little springs were a slight problem but other than that i cant remember ,sorry.. ... - .- -.
Post #185384 29th Apr 2013 7:12am
ahebron
New Zealand
I had a look in Rave today and its all there how to dismantle the seats.
Post #185695 30th Apr 2013 6:51am
TheAllSeeingPie
Yeah did it last night. You just need to take the side trims off and peel the leather off. Rather easy although the rings were a pig to fit back on. Seat feels a lot better but unfortunately I scratched the centre console piano black trim Big Cry
Post #185905 1st May 2013 6:34am
spanner
Hi where did you get foam from and cost
Post #185911 1st May 2013 7:11am
GreenBlood
United Kingdom 2012 Range Rover Westminster 4.4 V8 Orkney Grey
Good to know, thanks. If you don't get stuck then you are not trying hard enough.
2012 FFRR TDV8 Westminister
Gone: Def90 2.8i, Def110 2.8i
Gone: RRC 2-Door and 4-Door, 2007 FFRR TDV8 Vogue
Gone: Aussie Spec D1 V8, D2 V8
Post #185917 1st May 2013 8:15am
ahebron
New Zealand
Instead of refitting the rings could cable ties be used instead?
Post #185919 1st May 2013 8:23am
i wouldnt have thought so , there's a lot of weight and strain on these rings/clips.. ... - .- -.
Post #185921 1st May 2013 8:41am
TheAllSeeingPie
I'd recommend some hog ring pliers (around £12) so you don't have the fun I did doing it with normal pliers. Got the foam from Dan @ Duckworths
Post #185957 1st May 2013 12:06pm
