Home > Technical (L322) > Intermittent wipers that arnt!!
Page 1 of 3 123>
billsmith737
England 2009 Range Rover Vogue TDV8 Santorini Black
Just found another (!) problem with my new to me l322. the wipers work fine in every respect apart from intermittent, it doesn't matter what position the bezel on the stalk is in they just please them selves preferring to run at the lower speed but randomly miss the odd wipe......but...whilst sat in traffic they work as they should!....
any clues to this random behavior??
Thanks
Post #417764 13th Dec 2016 6:13pm
Have you got a rain sensor? .
Post #417778 13th Dec 2016 7:39pm
billsmith737
no Shocked ....well, not that im aware of.....odd thing is i just popped out and they worked.....well, in as much as intermittent but again adjusting the speed bezel apeared a waste of time......
Post #417780 13th Dec 2016 7:47pm
I would suspect rain sensor.
The intermittent wipers should be automatic depending on the level of rain - there would be a sensor by the rear view mirror.
Post #417781 13th Dec 2016 7:52pm
billsmith737
Hi, no, no sensor and the rain was very light, just a bit of drizzle realy hence why i just wanted a slow wipe as i ducked through traffic.....
Post #417783 13th Dec 2016 8:07pm
kbald
Im sure rain sensitive wipers were standard on the vogue! You need to put them into intermittent setting after the car is started for them to work as if you start with intermittent there is a fail safe incase of a frosty windscreen ruining the wiper blades. Try turning them on then pour water over the windscreen from a hose and see if they come on.
Post #417815 13th Dec 2016 10:28pm
The only way it could not have rain sensing wipers is if it has had a new windscreen and the wrong one was fitted without the blue window but that would still leave the small problem of the sensor still being there somewhere , is the windscreen dirty at all up at the blacked out bit around your mirror ? 2008 MY Supercharged
Post #417828 14th Dec 2016 2:51am
billsmith737
Aaahhh.....Ok, I was looking for a separate sensor, there is an oblong within the rear view mirror mount that can only be seen from outside...is that it?
With regards to its operation though...it's totally random...I can turn them on to inter. And off 20 times during a drive and they react just as they want....not how I want!...the speed bezel makes no change to them, most of the time they run as if on standard wipe but with the odd hickup, turn off and back on and they react differently...this was a sequence from the drive to work this morning..turned on to intermittent after 5 mins of driving,.. nothing for a min then 6 wipes, hickup, 3 wipes, hickup, 22 wipes, nothing for 30 seconds, 16 wipes, hickup, 4 wipes, then 1 wipe every 5 seconds for a minute, this was all in constant light drizzle...it's extremely annoying and draws my attention away from driving!....surely the randomness isn't how a rain sensor should be controlling them?
Post #417833 14th Dec 2016 6:38am
kbald
I think the windscreen may have a sensor in too. The rain sensor is random but is controlled by the amount of rain and heaviness so shouldn't be a distraction in fact should be the opposite and take the rain away without you thinking about it.
Sounds like there may be a fault with the sensor. Try cleaning the area where the sensor is or that sensor internally but that could be for he automatic headlights.
Post #417835 14th Dec 2016 7:36am
miggit
The sensor is behind the rearview mirror.. as you move the adjustment lever / dial on the wiper stalk it increases or decreases the sensitivity of the auto wipers.. when the lever is at 12 o'clock then it's at it's least sensitive Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #417841 14th Dec 2016 10:08am
alistairh
Mines was doing the same..easy to check..pull the connection to the sensor then try wipers..i ended up fixing mine by pulling the fuse and I reset the lot..
Post #417882 14th Dec 2016 2:30pm
billsmith737
Daft question maybe....but what does the sensor look like?...where exactly is it?
Post #417884 14th Dec 2016 2:36pm
alistairh
Its in the glass..basically behind the mirror.. Thumbs Up
Post #417887 14th Dec 2016 2:38pm
billsmith737
Just looked on YouTube...there's a video (for a sport)...showing it, it is the black oblong I thought it was, I'll pull the covers off and see if there is an obvious issue....
Post #417890 14th Dec 2016 2:42pm
like this ,
Post #417894 14th Dec 2016 3:13pm
Page 1 of 3 123>
