Home > Technical (L322) > Intermittent wipers that arnt!! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Have you got a rain sensor? .
13th Dec 2016 7:39pm |
billsmith737 Member Since: 03 Dec 2016 Location: Bradford Posts: 41 |
no ....well, not that im aware of.....odd thing is i just popped out and they worked.....well, in as much as intermittent but again adjusting the speed bezel apeared a waste of time...... |
13th Dec 2016 7:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7938 |
I would suspect rain sensor.
13th Dec 2016 7:52pm |
Hi, no, no sensor and the rain was very light, just a bit of drizzle realy hence why i just wanted a slow wipe as i ducked through traffic..... |
13th Dec 2016 8:07pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Im sure rain sensitive wipers were standard on the vogue! You need to put them into intermittent setting after the car is started for them to work as if you start with intermittent there is a fail safe incase of a frosty windscreen ruining the wiper blades. Try turning them on then pour water over the windscreen from a hose and see if they come on. |
13th Dec 2016 10:28pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
The only way it could not have rain sensing wipers is if it has had a new windscreen and the wrong one was fitted without the blue window but that would still leave the small problem of the sensor still being there somewhere , is the windscreen dirty at all up at the blacked out bit around your mirror ? 2008 MY Supercharged
14th Dec 2016 2:51am |
Aaahhh.....Ok, I was looking for a separate sensor, there is an oblong within the rear view mirror mount that can only be seen from outside...is that it?
14th Dec 2016 6:38am |
I think the windscreen may have a sensor in too. The rain sensor is random but is controlled by the amount of rain and heaviness so shouldn't be a distraction in fact should be the opposite and take the rain away without you thinking about it.
14th Dec 2016 7:36am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The sensor is behind the rearview mirror.. as you move the adjustment lever / dial on the wiper stalk it increases or decreases the sensitivity of the auto wipers.. when the lever is at 12 o'clock then it's at it's least sensitive Yesterday I couldn't spell Engineer... Today I are one!
14th Dec 2016 10:08am |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 |
Mines was doing the same..easy to check..pull the connection to the sensor then try wipers..i ended up fixing mine by pulling the fuse and I reset the lot.. |
14th Dec 2016 2:30pm |
Daft question maybe....but what does the sensor look like?...where exactly is it? |
14th Dec 2016 2:36pm |
Its in the glass..basically behind the mirror.. |
14th Dec 2016 2:38pm |
Just looked on YouTube...there's a video (for a sport)...showing it, it is the black oblong I thought it was, I'll pull the covers off and see if there is an obvious issue.... |
14th Dec 2016 2:42pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
like this ,
14th Dec 2016 3:13pm |
