![]() | Home > Technical (L322) > Intermittent wipers that arnt!! |
billsmith737 Member Since: 03 Dec 2016 Location: Bradford Posts: 41 ![]() ![]() ![]() |
could you tell me which fuse and where to find it please......new to the green oval, been a Jag man for 20 years and got tired of all the silly electrical niggles........oh......hang on a minute.....Jag and Land Rovers are what????,........... ![]() ![]() ![]() ![]() ![]() |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Its fuse f41 in the passenger side fuse box. Fixed my issue when I pulled it.have you tried unplugging the sensor first? |
Not yet mate, not had time, I'll do it tomorrow and see what it does and report back. Cheers for the info. |
abs66 Member Since: 26 Apr 2016 Location: Warrington Posts: 93 ![]() ![]() |
Just a thought, is it dark out when you have problems?
well, they appear to be ok now |
Sods law, my rain sensitive function seems to have stopped working haha.
if it helps ease the pain, mine are fine now, think it must have been a little leaf or something confusing the sensor.......but my rear wash is sh!t....... |
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 ![]() ![]() ![]() |
I know this is an old thread but I figured better not start another.
Rog21 Member Since: 09 Nov 2018 Location: Havant Posts: 62 ![]() ![]() ![]() |
Rain sensor work by detecting reflected light back from rain on windscreen, as previous quote said the sensitivity is altered by the stalk. If the sensor is not pressed correctly against the windscreen they do not work correctly, which is why pressing rear view mirror may fix it. In all my land rovers they can initially be fooled but usually settle down after a couple of wipes. |
Hi Rog21
Gordo51 Member Since: 16 Jul 2018 Location: Chilliwack Posts: 16 ![]() ![]() ![]() |
To remove the rain sensor you use a small screwdriver to push down on the top edges of the corners. The are vertical rectangular plastic latches that slide down to release it. If you look closely at the sides you can see the outline.
Thank you for your reply Gordo |
yelnats69 Member Since: 21 Dec 2019 Location: Dymchurch Posts: 35 ![]() ![]() ![]() |
My 2011 Vogue rain sensor seems to be held by a metal clip (see photo)
