Home > Maintenance & Mods (L322) > wiring up 2010 rear lights |
WHIZZ73 Member Since: 30 Jan 2011 Location: Hemel Hempstead Posts: 55 |
Hi,
21st Mar 2011 9:39pm |
That was tomorrows job?
21st Mar 2011 11:17pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
25w load resistor for the side lights and 50w load resistor for the indicators wired in as you would a bulb across the positive and negative, put load resistor in ebay theres plenty to go at. |
22nd Mar 2011 12:08am |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
As said before its the resistance value thats the key yes you need atleast 25watt resistors mounted to interior body this will eliminate all dash issues you can turn off lamp check in navcoder but you can not stop cold check so you will allways get a very quick lamp flicker |
22nd Mar 2011 7:07am |
So what resistance do they need to be(Ohms) ??
22nd Mar 2011 4:07pm |
BigJ Member Since: 16 Mar 2011 Location: North Yorkshire Posts: 247 |
Why is this seem to be such a super secret am I missing something? Used to have:
22nd Mar 2011 7:29pm |
I dont seem to be getting anywhere at the mo!
23rd Mar 2011 9:45pm |
i did the conversion on mine and after fitting the load resistors i havnt noticed any flashing what so ever, they all work as they should. there is no big secret at all, just get the resistors i said and they will all work fine. |
23rd Mar 2011 10:17pm |
OK, working out resistor values is relatively simple using Ohms Law. This states that:
23rd Mar 2011 10:53pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
A 'How To' of the 2010 tail light swap would be quite helpful I'm guessing, especially as I'm possibly thinking of swapping mine to 2010 spec tail lights....
23rd Mar 2011 11:28pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
i like smarties... ... - .- -. Y. O. L. O. . |
24th Mar 2011 7:43am |
So do I but Fiat Unos
24th Mar 2011 12:59pm |
mcanzio Member Since: 04 Jul 2011 Location: San Diego, CA Posts: 8 |
Any updates on this topic? I am still having problems with my rear fog lights always being on. I tried relays but the buzzing sound is soo loud when I turn on the lights. Any more info on this would be much appreciated.
4th Jul 2011 8:43pm |
there was a bloke on ebay selling a box that solved the fog light problem, cost 99 of our british pounds...looked today for the seller but cant find him at the moment. |
5th Jul 2011 7:08am |
