Home > Maintenance & Mods (L322) > wiring up 2010 rear lights
Page 2 of 3 <123>
WHIZZ73
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Hi,
Has anyone found a system that actually works?
I started playing today and have sussed the fog light problem but now have a fault on the dash plus the sides/indicators flash faster than my Mrs on a Friday night everytime I first start up
Is there a solution??
Please help
Post #55904 21st Mar 2011 10:39pm
daveo
hi there are a few kits out there that will do the job inc the fog light prob... the fast flashing of the indicators is down to the lcm checking for bulbs out, because leds use far less current then normal bulbs the small current the lcm puts down the wires to check the normal bulb, this would not be high enough to light it but with the led it will so thats why you see it flashing, are you using resistors... V8 facelift Range Rover Autobiography 22" wheels.
Post #55919 21st Mar 2011 11:54pm
WHIZZ73
That was tomorrows job?
Parallel or series? on both sides/fog/inds? someone has mentioned 50W resistors but what resistance etc Im getting to think I may have bitten off too much?
I really dont want to do what I would class as a bodge ie leaving old bulb holders hidden
Have you done yours?
Post #55921 22nd Mar 2011 12:17am
arron
United Kingdom 2005 Range Rover Vogue Td6 Java Black
25w load resistor for the side lights and 50w load resistor for the indicators wired in as you would a bulb across the positive and negative, put load resistor in ebay theres plenty to go at.
Post #55922 22nd Mar 2011 1:08am
oodathort
As said before its the resistance value thats the key yes you need atleast 25watt resistors mounted to interior body this will eliminate all dash issues you can turn off lamp check in navcoder but you can not stop cold check so you will allways get a very quick lamp flicker
Post #55924 22nd Mar 2011 8:07am
WHIZZ73
So what resistance do they need to be(Ohms) ??
So its not possible to stop the quick flash on start up then?
Surely DDC and the like have found a work around??
Post #55982 22nd Mar 2011 5:07pm
BigJ
United Kingdom 2005 Range Rover Vogue 4.4 V8 Stornoway Grey
Why is this seem to be such a super secret am I missing something? Used to have:
2005 FFRR 4.4 Vogue - BRC LPG Conversion & Remapped
Now have:
2008 SSRR 3.6 TDV8 - HSE and plenty of toys
Post #56039 22nd Mar 2011 8:29pm
WHIZZ73
I dont seem to be getting anywhere at the mo!
Need some more input from the clever ones on this site someone must have the answers other than Smarties Whistle
Post #56329 23rd Mar 2011 10:45pm
arron
i did the conversion on mine and after fitting the load resistors i havnt noticed any flashing what so ever, they all work as they should. there is no big secret at all, just get the resistors i said and they will all work fine. Thumbs Up
Post #56333 23rd Mar 2011 11:17pm
mzplcg
OK, working out resistor values is relatively simple using Ohms Law. This states that:
V=IR (Volts equals Current multiplied by resistance)
AND
P=VA (Power in watts equals volts multiplied by current in amperes)
So as an example, if you have a regular 21watt indicator bulb which you are replacing with a lower power LED unit of 4 watts you need to shunt enough current to make the 4 watt LED look like a 21watt globe. In other words, you need to force another 17watts of current draw.
So, 12 volts is known and 17 watts is also known. Thus 17/12=1.41 AMPS.
it follows that to shunt 1.41 amps at 12 volts requires about 8.5 ohms.
Now you have all values required to make a sensible selection. 17 watts so a 25 watt resistor (next value up) and 8.5 ohms which would sensibly be a 10 ohm unit (nearest available)
Hope this helps a bit
Dom
Post #56337 23rd Mar 2011 11:53pm
M44K TS
A 'How To' of the 2010 tail light swap would be quite helpful I'm guessing, especially as I'm possibly thinking of swapping mine to 2010 spec tail lights.... Whistle
Laughing 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #56342 24th Mar 2011 12:28am
i like smarties... ... - .- -.
Post #56353 24th Mar 2011 8:43am
WHIZZ73
So do I but Fiat Unos Laughing
I liked led rear lights at the start of the week but now they're quickly....
And to thing I've still got the front to do after this!
I must be mad Rolling with laughter
Post #56430 24th Mar 2011 1:59pm
mcanzio
United States 2008 Range Rover Westminster Supercharged Java Black
Any updates on this topic? I am still having problems with my rear fog lights always being on. I tried relays but the buzzing sound is soo loud when I turn on the lights. Any more info on this would be much appreciated.
Cheers 1) 2008 Range Rover Supercharged Westminster (Converted to 2010+ MY)
2) 2001 P38 4.6HSE w/ 2" Lift on 32" BFG KM2's
Post #71193 4th Jul 2011 9:43pm
there was a bloke on ebay selling a box that solved the fog light problem, cost 99 of our british pounds...looked today for the seller but cant find him at the moment.
Post #71217 5th Jul 2011 8:08am
Page 2 of 3 <123>
