![]() | Home > Technical (L322) > L322 electronics driving me crazy!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8555 ![]() ![]() ![]() |
Any auto electrician can find a parasitic drain, it's pretty easy to do with a meter, nothing special about it being an FF... |
Lenb Member Since: 03 Sep 2014 Location: Leicester Posts: 132 ![]() ![]() ![]() |
Have you tried the Hevac panel? Since wiring mine to switch off when ignition off I have had no problem with battery drain. Can leave it a week now with no problem. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Roverlord Member Since: 20 Aug 2016 Location: london Posts: 29 ![]() ![]() ![]() |
The final speed resister is usually a likely suspect. Search FSR on this forum |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Have a Google for final stage resistor as that is most common fault, there is one method to replace below but I have heard of easier methods also probably on this forum.
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
As others have said, first thing to look at would be the final stage resistor as it's such a common problem, also check your electrics in the boot, if there is any water ingress it needs sorted 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
kiranl322 Member Since: 07 Jan 2016 Location: london Posts: 18 ![]() ![]() ![]() |
Thanks for the feedback guys! Well I bought a replacement FSR tried it, but still no luck! Checked the boot DVD and goes off when the cars shut, I did noticed a type of vacum sound coming from around the clock area when I close the car (while I'm inside) does anyone know if that's the problem or what that could be? |
Might sound like a silly question but what is the Hevac panel? |
Also does anyone know about a wiring harness upgrade? Mines a 2003 53 model |
Hevac HEating Ventilation Air Conditioning...
Cheers for getting back to me Pete, checked it with a volt meter and it turns up nothing so apparently there's no drain?? Can I repair my hevac unit or buy second hand and try for luck, if I disconnect the FSR what will happen? What actually does it do? If I leave it disconnected what effect does it have, cheers! |
So you have checked every fuse for a power drain when the FF has gone to sleep...??? Pete
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
We hope you are using a meter, not across the terminals, but inline, with one terminal....on amps.
Yep been running it in-line, seriously I'm clutching at straws with this, can anyone help me out? Or give me number of someone who can at least find the problem for me, I'm based in the west London area, cheers for all the help so far! |
Yep checked them all to the best of my knowage and all seem fine |
