Home > Technical (L322) > L322 electronics driving me crazy!!!
kiranl322
United Kingdom 2003 Range Rover Vogue SE Td6 Epsom Green
Hello all,
I have come to my wits end with my 2003 RR Vogue, for some reason unknown to me that brattery drains tried a few things like making sure the heater control is off, Nav player turns off and gear selector indicator is off still to now avail, are there any electronic wizards around West London or know of anyway that could help save my sanity! Thanks in advance Thumbs Up
Post #416074 30th Nov 2016 10:38pm
Any auto electrician can find a parasitic drain, it's pretty easy to do with a meter, nothing special about it being an FF... Thumbs Up Pete
Post #416079 30th Nov 2016 11:14pm
Lenb
England 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Re: L322 electronics driving me crazy!!!
Have you tried the Hevac panel? Since wiring mine to switch off when ignition off I have had no problem with battery drain. Can leave it a week now with no problem. Current: 2004 Vogue 4.4 V8 - 2004 Discovery 2
Previous: 2000 P38 DHSE - 1995 P38 DT Man - 1990 3.9 SE Classic, 1980 3.5 Classic 2dr
Post #416111 1st Dec 2016 12:51am
Roverlord
England 2003 Range Rover HSE Td6 Zambezi Silver
The final speed resister is usually a likely suspect. Search FSR on this forum
Post #416119 1st Dec 2016 3:22am
holidaychicken
Have a Google for final stage resistor as that is most common fault, there is one method to replace below but I have heard of easier methods also probably on this forum.
http://www.rswsolutions.com/index.php/mkii...e-resistor
Check in Rave for which fuse supplies that and leave it out when not in the RR to see if that helps.
Also faulty headlight wipers not parking correctly so again pull the fuse, can sometimes be cured by taking the wipers off and operating them and then refitting
Be careful pulling fuses for radio / satnav as needs to shut down before disconnecting power
A fuse buddy can help to show current drain across a fuse when vehicle shut off, it connects in place of a fuse.
Post #416121 1st Dec 2016 7:11am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
As others have said, first thing to look at would be the final stage resistor as it's such a common problem, also check your electrics in the boot, if there is any water ingress it needs sorted 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #416126 1st Dec 2016 8:39am
kiranl322
Thanks for the feedback guys! Well I bought a replacement FSR tried it, but still no luck! Checked the boot DVD and goes off when the cars shut, I did noticed a type of vacum sound coming from around the clock area when I close the car (while I'm inside) does anyone know if that's the problem or what that could be?
Post #416373 2nd Dec 2016 9:55pm
kiranl322
Might sound like a silly question but what is the Hevac panel?
Post #416374 2nd Dec 2016 9:56pm
kiranl322
Also does anyone know about a wiring harness upgrade? Mines a 2003 53 model
Post #416376 2nd Dec 2016 10:09pm
Hevac HEating Ventilation Air Conditioning...
You don't need a wiring harness upgrade, you need a meter and a few hours to work through the system to find where your parasitic drain is, plenty of info on Google and videos on youtube to tell you how to do it...
Or just keep changing bits till it's gone, but that tends to cost a lot of money... Thumbs Up Pete
Post #416380 2nd Dec 2016 10:26pm
kiranl322
Cheers for getting back to me Pete, checked it with a volt meter and it turns up nothing so apparently there's no drain?? Can I repair my hevac unit or buy second hand and try for luck, if I disconnect the FSR what will happen? What actually does it do? If I leave it disconnected what effect does it have, cheers!
Post #416383 2nd Dec 2016 10:46pm
So you have checked every fuse for a power drain when the FF has gone to sleep...??? Pete
Post #416387 2nd Dec 2016 11:04pm
johnboyairey
We hope you are using a meter, not across the terminals, but inline, with one terminal....on amps.
I don't want to lecture anyone, without brushing up on my skills, ( ages since doing this... on a p38) but I seem to remember that's the procedure, and you leave it on the bonnet, with it shut, (connected) and lock the car. -and observe it drop as it goes to sleep. Hopefully.
YouTube it
Post #416392 2nd Dec 2016 11:19pm
kiranl322
Yep been running it in-line, seriously I'm clutching at straws with this, can anyone help me out? Or give me number of someone who can at least find the problem for me, I'm based in the west London area, cheers for all the help so far!
Post #416515 3rd Dec 2016 10:13pm
kiranl322
Yep checked them all to the best of my knowage and all seem fine
Post #416516 3rd Dec 2016 10:15pm
