Home > General (L405) > well the bubble has burst (fixed) |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 137 |
My first problem after 11 months of trouble free driving the car has let me down - neither of the smart keys are working
13th Nov 2016 10:54am |
JasM Member Since: 08 May 2015 Location: Lanarkshire Posts: 220 |
Call out LR assistance 2014 SDV8 Autobiography
13th Nov 2016 12:01pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 |
+1 LR Assistance has to be the way to go |
13th Nov 2016 12:38pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Why should they charge you for investigation if it's only a year old? Agueroooooooooo. 93-20
13th Nov 2016 1:08pm |
Now you mention it mine was in for 1st service 3 weeks ago and the dealer asked for both keys to do an update. Agueroooooooooo. 93-20
13th Nov 2016 2:07pm |
just discovered I can lock it with the skeleton key , don't know why I didn't try that earlier must be an age thing
13th Nov 2016 2:34pm |
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1152 |
Good question, why? |
13th Nov 2016 3:24pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
The update is to replace the Key Validation Module so that it is now read-only so that anyone breaking into the car cannot then create a new key from the OBD port. That is why both keys are needed because they have to be matched to the KVM |
13th Nov 2016 4:37pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 811 |
How far back does it go please? |
14th Nov 2016 5:58pm |
visited Stratstone Aylesbury yesterday
16th Nov 2016 9:27am |
Not heard of that one.
16th Nov 2016 10:18am |
think I shall try restoring default settings on sat nav to see if that sorts it
16th Nov 2016 10:32am |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I've accidentally turned my Sat Nav volume down several times now - if you happen to alter your music volume as the Sat Nav says something, you end up turning that volume level down instead. Easiest way to get it back, assuming you have a destination set, is to go onto the Sat Nav map and touch the speaker looking icon at the top of the screen towards the right to make the Sat Nav repeat its last directions and as you do this, turn up the volume knob to the preferred level. If the voice ends and still isn't loud enough, just repeat it (I find it easier than guessing what level to set it at in the audio volume setup menu). Steve
19th Nov 2016 3:22pm |
