Home > General (L405) > well the bubble has burst (fixed)
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
My first problem after 11 months of trouble free driving the car has let me down - neither of the smart keys are working Big Cry
got into the car using the skeleton key turned off the alarm and managed to start it all seems to be working ok
even managed to get the folding mirrors back into their normal driving position
each time I enter the car and press the start button it says " smart key not found" so have to use the emergency method of holding key against the steering column
the battery voltage is showing 12.6v with engine off and 14.8volts with engine running - so I don't think its a battery issue but of course it could be !
plugged in the iiD BT tool it does not show any faults at all Question I don't think the iid tool can re-programme the keys on the 2016MY
had already arranged for its first ever service on 15th Nov at the dealers I bought it from,
notified them of this fault they say they will investigate and hopefully rectify under warranty, with a bit of luck all on the same day, there maybe a charge for the investigation so fingers crossed
I will find out how good the well known JLR dealer whose name begins with 'S' in Aylesbury is Whistle
but in the meantime I don't think I'm unable to lock or alarm the car, but at least I can drive it
any one got any ideas ? various other LR's this one is still the best
Post #413375 13th Nov 2016 10:54am
JasM
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
Call out LR assistance Thumbs Up 2014 SDV8 Autobiography Cool
Gone: 2012 RRS SDV6 HSE, 2007 RRS TDV6 HSE
Post #413380 13th Nov 2016 12:01pm
+1 LR Assistance has to be the way to go Thumbs Up
Post #413382 13th Nov 2016 12:38pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Why should they charge you for investigation if it's only a year old? Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #413384 13th Nov 2016 1:08pm
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
There is a recall on this age of car to sort the smart key, how surprising your dealer failed to tell you this. letters not necessarily in the right order
Post #413389 13th Nov 2016 2:01pm
Pfazz
Now you mention it mine was in for 1st service 3 weeks ago and the dealer asked for both keys to do an update. Agueroooooooooo. 93-20
Post #413390 13th Nov 2016 2:07pm
philbathurst
just discovered I can lock it with the skeleton key , don't know why I didn't try that earlier must be an age thing Embarassed
as I can drive it its not too much of a hassle so I shan't bother with LR assistance, just hope its simple free fix various other LR's this one is still the best
Post #413393 13th Nov 2016 2:34pm
caymanblack
Good question, why?
Post #413396 13th Nov 2016 3:24pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
The update is to replace the Key Validation Module so that it is now read-only so that anyone breaking into the car cannot then create a new key from the OBD port. That is why both keys are needed because they have to be matched to the KVM
Post #413405 13th Nov 2016 4:37pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Smart key recall
How far back does it go please?
Post #413573 14th Nov 2016 5:58pm
philbathurst
all sorted
visited Stratstone Aylesbury yesterday
Key Validation Module replaced under warranty & 1st service cost £439, everything only took 3.5 hours, all working OK now
quite impressed with their service Very Happy
however noticed on the way home when sat nav gives directions the radio does not mute Shocked not sure if its something I've adjusted
anyone got any ideas ? various other LR's this one is still the best
Post #413877 16th Nov 2016 9:27am
Not heard of that one.
The volume for the sat nav is set by adjusting the volume when the sat nav is talking - so may be worth trying a volume adjustment.....
Post #413887 16th Nov 2016 10:18am
philbathurst
think I shall try restoring default settings on sat nav to see if that sorts it
well that didn't work
have run out of ideas other than pulling the fuses and resetting the whole infotainment system ( do they still call it that ?) various other LR's this one is still the best
Post #413889 16th Nov 2016 10:32am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I've accidentally turned my Sat Nav volume down several times now - if you happen to alter your music volume as the Sat Nav says something, you end up turning that volume level down instead. Easiest way to get it back, assuming you have a destination set, is to go onto the Sat Nav map and touch the speaker looking icon at the top of the screen towards the right to make the Sat Nav repeat its last directions and as you do this, turn up the volume knob to the preferred level. If the voice ends and still isn't loud enough, just repeat it (I find it easier than guessing what level to set it at in the audio volume setup menu). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #414378 19th Nov 2016 3:22pm
