Home > Technical (L322) > front sensors stopped working |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
I'd say... they will allow you to see everything that a Land rover technician can see... but in the comfort of your own seat and without the price tag that's attached to a trip to the stealers... In fact I don't think that there is any thing that the LR testbook will do that the IID tool can't do either......... If you plan to stick with LR products get the BT IID as they will work with the entire modern range, and while you will have to buy extra licences for it I think it's only £25 a go
17th Nov 2016 4:21pm |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
HI JOHN
17th Nov 2016 4:33pm |
hi Miggit
17th Nov 2016 4:46pm |
are you just randomly hitting buttons?
17th Nov 2016 5:55pm |
who me as if i would; yes it might show the problem as you say, i will probably get one if it not tooooooooooooooooooooooooooo much beer token's
17th Nov 2016 6:19pm |
Just plug Weegie's IID in to your car, it should read the data, just wont let you change anything... so you wont be able to play with the height, or set the lazy lock, but you should be able to see if there is a fault showing for the PDC. I can't say for sure if it will work as I don't know which IID tool Weegie has, but I was able to access injector live data with my BT tool on another ffrr that wasn't vin locked to the tool Yesterday I couldn't spell Engineer... Today I are one!
17th Nov 2016 10:21pm |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
If one is not working all will stop on that side.
18th Nov 2016 7:54am |
