![]() | Home > Technical (L322) > Select Neutral |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 45 ![]() ![]() ![]() |
Hi all,
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1002 ![]() ![]() |
I would say low battery voltage and/or a faulty transfer box shift motor potentiometer. Doesn’t sound like a transmission issue to me.
Hi Phil,
The shift motors are just plug-n-play, they aren't coded to the ECU/vehicle.
Oh, and just check that you don't have a fuse installed in position 37
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Transfer box motors are now being refurbed (including a new poteniometer) for a more sensible price and with a years warranty.
Considering the problems people have experienced in the past trying to fix this isue thats excellent news , well found ![]() I know that address can't go in the Wiki but it needs to be stored somewhere doesn't it ? 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
Just to give hopefully all the answers regarding the Transfer Box motor (2002-2006) have a look here:
No fuse in 37, thank god, that would have been embarrassing!
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I suspect a new one will have the same problem if the battery voltage is down. If you turn the ignition on with your window open you should hear the motor move a little as it finds it's position. The other thing you can check is whether (with battery voltage good) you can shift into and out of low range. Repeatedly.
Hi,
If you can go in and of of low reliably, I'd be looking at the voltage. However, a scan with a RR specific scanner may give you more info (I'm not sure about that).
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8557 ![]() ![]() ![]() |
Diagnostic units won't pinpoint battery drain...
No coolant loss at all, might see if I can get a LR scan?? |
