Home > Technical (L322) > Select Neutral |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 |
Hi all,
15th Oct 2016 6:40pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 964 |
I would say low battery voltage and/or a faulty transfer box shift motor potentiometer. Doesn’t sound like a transmission issue to me.
15th Oct 2016 6:49pm |
Hi Phil,
15th Oct 2016 6:57pm |
The shift motors are just plug-n-play, they aren't coded to the ECU/vehicle.
15th Oct 2016 7:05pm |
Oh, and just check that you don't have a fuse installed in position 37
15th Oct 2016 7:14pm |
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 417 |
Transfer box motors are now being refurbed (including a new poteniometer) for a more sensible price and with a years warranty.
15th Oct 2016 9:31pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Considering the problems people have experienced in the past trying to fix this isue thats excellent news , well found I know that address can't go in the Wiki but it needs to be stored somewhere doesn't it ? 2008 MY Supercharged Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
16th Oct 2016 12:46am |
Just to give hopefully all the answers regarding the Transfer Box motor (2002-2006) have a look here:
16th Oct 2016 10:17am |
No fuse in 37, thank god, that would have been embarrassing!
16th Oct 2016 11:03am |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
I suspect a new one will have the same problem if the battery voltage is down. If you turn the ignition on with your window open you should hear the motor move a little as it finds it's position. The other thing you can check is whether (with battery voltage good) you can shift into and out of low range. Repeatedly.
16th Oct 2016 12:59pm |
Hi,
16th Oct 2016 2:01pm |
If you can go in and of of low reliably, I'd be looking at the voltage. However, a scan with a RR specific scanner may give you more info (I'm not sure about that).
16th Oct 2016 2:10pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8202 |
Diagnostic units won't pinpoint battery drain...
16th Oct 2016 3:18pm |
No coolant loss at all, might see if I can get a LR scan?? |
16th Oct 2016 3:47pm |
