Home > Technical (L322) > Aux Heating
Page 3 of 3 <123
krisleeds
What about the random no clicking tho. Then it's not so simple 😂
Post #409639 17th Oct 2016 5:30pm
Rewmer
The clicking is the fuel pump. When the heater fires it does its checks and if the voltage is below the threshold it won't activate the pump and then shut down. No7 - 2003 V8 Vogue
Post #409641 17th Oct 2016 5:38pm
Mightymarcos
Just read this trail and it all feels very familiar. My experience was similar last winter. The stuff on the 75 and ZT forum on the link above is great and the symptoms you describe are just what I had a year ago. After removing the heater I stripped it as per the on line guides and after cleaning and refitting got the thing to work. Unfortunately what it really needed was a n w glow plug to work reliably but a clean and seeing it work once made it worth shelling out �50 for a service kit. (takes about 20 mins with the suspension set high to get the wheel arch liner out and remove the heater now I am practiced)
Nice and toasty every day this winter so far so stick with it - it was worth it! Taking a rest from Land Rovers for a bit.......
Post #409744 18th Oct 2016 6:43pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
^ Thumbs Up
Post #409797 19th Oct 2016 1:55am
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
7 degrees this morning
My FBH sprang into life !
Yay. It somehow reset itself.
Clever machine.
Post #410247 22nd Oct 2016 10:13am
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Wow, well done. Mine still winds up but then it crackles and and shuts down 😔
Post #410250 22nd Oct 2016 10:34am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi mines working but not sure if it's as warm as it should be , do you need to leave it on for the full 30 mins ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #410261 22nd Oct 2016 1:11pm
Rambles
The full 30 minutes
Yes, is best
Although LR pathetically think 17 minutes is enough for the MY11 and 12s.....
Post #410289 22nd Oct 2016 5:34pm
dolph34
Thanks , I'll stick with 1/2 hour then 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #410392 23rd Oct 2016 5:56pm
Jase71
Finally got my FBH working..it just needed re-priming and now works a treat!
Post #417249 9th Dec 2016 12:34pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
How do you re-prime them? Mine seems fine but gets as far as a steadily increasing speed of clicking then shuts down..
Post #417527 11th Dec 2016 7:06pm
Page 3 of 3 <123
