![]() | Home > General > Temp Gauge |
After driving for about 40 mins my temperature gauge sits mostly at this mark , anyone else's do this .......
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35480 ![]() ![]() |
mines goes to the vertical middle mick, always has done... ... - .- -.
47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048 ![]() ![]() |
Yip, time to change the thermostat |
Yeah happens when the A/C is on as i said can drive for about 40 mins and it stays at the point in the picture then for no reason moves to the middle vertical position if i am sitting idling for 5 /10 mins .....
mine doesnt move either with or without a/c on... ... - .- -.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
![]() Probably time for the spanners then Mick Ian |
mick, have you checked the coolant levels..seems like theres a strain on the system somewhere. ... - .- -.
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 ![]() ![]() ![]() |
yea, reckon your stats stuck open mate. 2004 black Vogue TD6 |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Every VW I've had took forever to warm up. I've had three Transporter vans and currently have a Golf TDi as a runabout. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
A part of my thermostat housing broke off and wedged the thermostat open not long after I bought my car in Jan. That caused the gauge to sit quite low like that. Apparently, it's quite a common thing on BMW's I was told, something to do with there being 3 sensors inside the housing, 2 replaceable and one which isn't, it was the one that's not replaceable which broke off and got wedges meaning a new housing was needed.
It should make no difference if the AC is on at all, when the thermostat is closed there is no water flowing around the radiator to be chilled by the ac fan - that and the fact the fan doesn't come on unless the evaporator temp rises too much... I agree with the general consensus that you need a new stat! ![]() |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
What would fluctating gauge mean?
Hows your antifreeze mix? Maybe a partially blocked radiator from Ice Slush? ![]() |
Not sure will test mix.
