Home > General > Temp Gauge
Temp Gauge
After driving for about 40 mins my temperature gauge sits mostly at this mark , anyone else's do this .......
but when i stop and sit waiting on SWMBO for about five / ten mins the gauge moves to the middle ....
Guessing the thermostat is on its way out ...... Confused
Post #40786 4th Dec 2010 11:41am
mines goes to the vertical middle mick, always has done... ... - .- -.
Post #40791 4th Dec 2010 12:03pm
Yip, time to change the thermostat
Post #40794 4th Dec 2010 12:11pm
T24RES
Is the A/C on? My wifes vw sharan does that in the winter due to the extra fan running. Once switched off manually all is well. Ian
Post #40799 4th Dec 2010 12:20pm
Yeah happens when the A/C is on as i said can drive for about 40 mins and it stays at the point in the picture then for no reason moves to the middle vertical position if i am sitting idling for 5 /10 mins .....
Have noticed it does it more when the temp outside is about -5
Post #40801 4th Dec 2010 12:23pm
mine doesnt move either with or without a/c on... ... - .- -.
Post #40804 4th Dec 2010 12:26pm
T24RES
Probably time for the spanners then Mick Ian
Post #40806 4th Dec 2010 12:30pm
mick, have you checked the coolant levels..seems like theres a strain on the system somewhere. ... - .- -.
Post #40807 4th Dec 2010 12:33pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
yea, reckon your stats stuck open mate. 2004 black Vogue TD6
Post #40821 4th Dec 2010 1:36pm
Andy
Every VW I've had took forever to warm up. I've had three Transporter vans and currently have a Golf TDi as a runabout. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #40933 5th Dec 2010 1:26pm
M44K TS
A part of my thermostat housing broke off and wedged the thermostat open not long after I bought my car in Jan. That caused the gauge to sit quite low like that. Apparently, it's quite a common thing on BMW's I was told, something to do with there being 3 sensors inside the housing, 2 replaceable and one which isn't, it was the one that's not replaceable which broke off and got wedges meaning a new housing was needed.
Over the last week or so with the crazy low outside temperatures, mine's been sitting bang on half way regardless. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #40935 5th Dec 2010 1:39pm
dan_uk_1984
It should make no difference if the AC is on at all, when the thermostat is closed there is no water flowing around the radiator to be chilled by the ac fan - that and the fact the fan doesn't come on unless the evaporator temp rises too much...
I agree with the general consensus that you need a new stat!
Post #40954 5th Dec 2010 3:18pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
What would fluctating gauge mean?
Started fine then on to gas fine, then twenty mins in very high then very low.
Stopped and checked all good.
Running low for rest of journey.
Normal levels this afternoon when cooled.
Normally steady as a rock bang in the middle.
Was minus ten this morning. 15MY SDV8 Vogue SE
Post #41347 7th Dec 2010 5:29pm
dan_uk_1984
Hows your antifreeze mix? Maybe a partially blocked radiator from Ice Slush?
Post #41348 7th Dec 2010 5:32pm
Jem0911
Not sure will test mix.
On the way home would not get out of second sector.
Took ages to change over to gas?
Warmed up when stationary but not close to morm. 15MY SDV8 Vogue SE
Post #41353 7th Dec 2010 6:30pm
