![]() | Home > Maintenance & Mods (L322) > Always fit new pads when fitting new Brake Discs? |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
No idea if its necessary but I would The forums premier drug dealer and human trafficking consultant
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yes I would, solely because you dont know if the pads are worn in different places, plus if its stripped down already, for the extra cost you may as well do it. |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3255 ![]() ![]() ![]() |
You need another category:
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 ![]() ![]() ![]() |
I've always thought this to be essential. The pads will be worn to the profile of the previous disc. Therefore they won't make full contact with a new disc and depending on how bad the profile of the old disc was this may well take a long time, during which you have an impaired braking system.
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Essential. Pads wear to the disc, new disc new profile and reduced friction material = potential loss of brakes. |
Well, I might get slated for this but I have re-fitted used pads with new discs but I did take a moment to ensure they were flat using a very coarse file. This was only due to the fact it was a Sunday, I couldn't get new pads as they were out of stock and I had to do the job to replace a cracked disc.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35618 ![]() ![]() |
in an ideal world i would fit new pads with new discs , but at £200 for pads i would try the slightly worn pads and use Dom's method of lightly cleaning the pads up with a file... ... - .- -.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8000 ![]() ![]() ![]() |
Well it's no worse than putting new pads onto old discs..... the contact area is reduced.... I'm in the 'highly desirable' camp - the old pads will have work to the profile of the old discs, so will put uneven wear on the new discs right from the outset. What you save on not buying new pads is somewhat offset by reducing the life of the new discs. |
How could you ???...its 40 lashes for you ![]() Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III. |
40 nights of getting lashed eh Jim? Works for me |
Not talking about our own RR by the way... I always would but was curious as to the technicality correct answer.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1557 ![]() ![]() |
If the pads have plenty of life left, I flatten them and reuse them. The labour isn't an issue as I'm not paying anyone to do the job. Ron B. VK2OTC
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6761 ![]() ![]() ![]() |
I usually find that the pads are gubbed by the time the disc needs replaced. Got - 2017 SDV8 Autobiography in Loire Blue
Like most of the posts.. our trusted mechanic has since advised ALWAYS fit new pads if fitting new discs (despite the fact the pads in question have 70% life left...
