Home > Maintenance & Mods (L322) > Always fit new pads when fitting new Brake Discs?
Yes, essential.
85%
 85%  [29]
No, unnecessary.
8%
 8%  [3]
Don't know
5%
 5%  [2]
Total Votes: 34
pld118
Hi,
A. If front brake discs are lipped/ scored is that the most obvious reason for juddering under braking (newly fitted tyres made no difference)?
B. Brake pads are only 30% worn so if fitting new brake discs is it essential to fit new pads?
Thanks
Post #404811 15th Sep 2016 11:18am
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
No idea if its necessary but I would The forums premier drug dealer and human trafficking consultant
Range Rover Vogue SE 4.4 TDV8, Range Rover Sport HSE 3.6TDV8, Audi S8 V10, Jaguar XKR Conv, Jaguar XJS V12 Conv, Land Rover Disco 3, Lexus LS 400 MkIV, Lexus LS400 Mk III.
Post #404812 15th Sep 2016 11:26am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Yes I would, solely because you dont know if the pads are worn in different places, plus if its stripped down already, for the extra cost you may as well do it.
Post #404814 15th Sep 2016 11:31am
Weegie
You need another category:
"May not be essential but would anyway."
Thumbs Up John
GAP iiD BT-Sold
Post #404815 15th Sep 2016 11:37am
mike whiskey
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I've always thought this to be essential. The pads will be worn to the profile of the previous disc. Therefore they won't make full contact with a new disc and depending on how bad the profile of the old disc was this may well take a long time, during which you have an impaired braking system.
Given all the labour is going to be done anyway, why on earth wouldn't you?
MW Car history includes: LR Series 3, RR Classic x 4, LR 101, Discovery 1 and 2 and now FFRR.
Yes I'm a masochist....
Post #404816 15th Sep 2016 11:54am
Clivefog
Essential. Pads wear to the disc, new disc new profile and reduced friction material = potential loss of brakes.
Post #404818 15th Sep 2016 11:58am
mzplcg
Well, I might get slated for this but I have re-fitted used pads with new discs but I did take a moment to ensure they were flat using a very coarse file. This was only due to the fact it was a Sunday, I couldn't get new pads as they were out of stock and I had to do the job to replace a cracked disc.
Not entirely the best way of doing things but on balance it was better than driving with a cracked disc. Wasn't on a FFRR either, just my old work hack. Given the choice I always fit new pads.
The comments about non-matching profiles though, well that is what you get with new pads and used discs. In this scenario there is a longer bed-in time than when replacing the lot and this is something we have all done for many years. It's very pronounced on sliding calipers as well. The pads in my Skoda always wear in a taper so the discs actually get more wear on the innermost part where the caliper exerts most force. With new pads, a few miles of gentle braking soon sorts that out.
Post #404819 15th Sep 2016 12:08pm
in an ideal world i would fit new pads with new discs , but at £200 for pads i would try the slightly worn pads and use Dom's method of lightly cleaning the pads up with a file... ... - .- -.
Post #404827 15th Sep 2016 1:15pm
Well it's no worse than putting new pads onto old discs..... the contact area is reduced....
I'm in the 'highly desirable' camp - the old pads will have work to the profile of the old discs, so will put uneven wear on the new discs right from the outset.
What you save on not buying new pads is somewhat offset by reducing the life of the new discs.
Post #404829 15th Sep 2016 1:17pm
wackyjim
How could you ???...its 40 lashes for you Laughing The forums premier drug dealer and human trafficking consultant
Post #404832 15th Sep 2016 1:31pm
mzplcg
40 nights of getting lashed eh Jim? Works for me Thumbs Up
Post #404840 15th Sep 2016 1:46pm
pld118
Not talking about our own RR by the way... I always would but was curious as to the technicality correct answer.
Surprised at how many replies so sooon but thanks Thumbs Up
Ps... IMO... good counter observation about when fitting new pads with existing discs...
Post #404844 15th Sep 2016 2:37pm
p38arover
Australia
If the pads have plenty of life left, I flatten them and reuse them. The labour isn't an issue as I'm not paying anyone to do the job. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #404851 15th Sep 2016 3:39pm
I usually find that the pads are gubbed by the time the disc needs replaced. Got - 2017 SDV8 Autobiography in Loire Blue
Post #404911 15th Sep 2016 8:21pm
pld118
Like most of the posts.. our trusted mechanic has since advised ALWAYS fit new pads if fitting new discs (despite the fact the pads in question have 70% life left...
Post #404914 15th Sep 2016 8:32pm
