Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 |
When our FFRR starts it runs rough, i'm guessing it is missing because there is a definitive smell of fuel out of the exhaust - on petrol & gas.
12th Sep 2016 10:15pm |
*lpg not log |
13th Sep 2016 8:45am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
title edited for you ... - .- -.
13th Sep 2016 8:46am |
Cheers Stan
13th Sep 2016 8:53am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8205 |
Is that just starting from cold or does it do it when hot..??? Pete
13th Sep 2016 10:38am |
So if we've been driving and turn the engine off then back on again it'll run rough again so yes it does it when hot too |
13th Sep 2016 10:48am |
The engine ECU richens the mixture on cold start for a while, similar to the old choke, mine smells of fuel if you stand at the back as well when this is happening..
13th Sep 2016 10:55am |
The radiator coolant temp looks low.
13th Sep 2016 12:25pm |
After driving a short distance and issue is not occurring
13th Sep 2016 12:44pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
Maybe a leak in the vapouriser which seals up when hot? |
13th Sep 2016 1:06pm |
It does it on petrol as well |
13th Sep 2016 1:11pm |
If it was a missfire you would have a MIL light on...
13th Sep 2016 1:42pm |
When I turn it off then on again it is lumpy straight away.
13th Sep 2016 2:41pm |
Check the STFT (short term fuel trims) with it running and see how far out they are, should be within + or - 10%
13th Sep 2016 3:32pm |
I'm not sure what the short fuel trims will come under? I can't find them
13th Sep 2016 5:01pm |
