Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
When our FFRR starts it runs rough, i'm guessing it is missing because there is a definitive smell of fuel out of the exhaust - on petrol & gas.
When the engine has been running on idle a few minutes it settle andirons silky smooth.
Also more throttle gives a smoother run - although on return to idle it'll idle rough again during the first 2-3 minutes
The roughness can come back if sat in traffic for a while.
I have a Carsoft i930 so I can take some readings if someone could point me what to measure?
Post #404560 12th Sep 2016 11:15pm
ohuntsman
*lpg not log Embarassed
Post #404584 13th Sep 2016 9:45am
title edited for you Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #404585 13th Sep 2016 9:46am
ohuntsman
Cheers Stan Mr. Green
Any ideas buddy???
Post #404587 13th Sep 2016 9:53am
Is that just starting from cold or does it do it when hot..??? Pete
Post #404602 13th Sep 2016 11:38am
ohuntsman
So if we've been driving and turn the engine off then back on again it'll run rough again so yes it does it when hot too
Post #404606 13th Sep 2016 11:48am
The engine ECU richens the mixture on cold start for a while, similar to the old choke, mine smells of fuel if you stand at the back as well when this is happening..
I would imagine, for some reason, the ECU is doing this on every start... could be the coolant temperature sender is defective and showing it being very cold, this would make it too rich even on the first start......
Does the temp gauge work??
Try some live values from the coolant sensor, there are two, an engine temp and a radiator temp.... Thumbs Up Pete
Post #404611 13th Sep 2016 11:55am
ohuntsman
The radiator coolant temp looks low.
I neglected to mention that when idle smooths out and you lightly touch the throttle for reversing or manuevering below 1000rpm it splutters.
Post #404620 13th Sep 2016 1:25pm
ohuntsman
After driving a short distance and issue is not occurring
Post #404622 13th Sep 2016 1:44pm
mr_spock
Maybe a leak in the vapouriser which seals up when hot?
Post #404625 13th Sep 2016 2:06pm
ohuntsman
It does it on petrol as well
Post #404626 13th Sep 2016 2:11pm
If it was a missfire you would have a MIL light on...
Yep, temp seems to be working OK, next thing is leaking injectors flooding the engine when you switch off, does it happen if you switch off and start again immediately...??
If your diaphragm is split it will run poorly on LPG, I take it it's fine on LPG...???
There are lots of things it can be, just covering the easy ones first.... Thumbs Up Pete
Post #404631 13th Sep 2016 2:42pm
ohuntsman
When I turn it off then on again it is lumpy straight away.
It behaves the same on lpg as it does on petrol
Post #404634 13th Sep 2016 3:41pm
Check the STFT (short term fuel trims) with it running and see how far out they are, should be within + or - 10%
Also check the lambda sensors, they should swing between around 0v to 1v then back again.... Thumbs Up
I take it there aren't any fault codes logged...??? Pete
Post #404642 13th Sep 2016 4:32pm
ohuntsman
I'm not sure what the short fuel trims will come under? I can't find them
Lambda sits at 1 then when rough goes up to 1.23 or 1.4, doesn't drop below 0.95
I cleared a load of codes yesterday- thinking I had taken photos of them all, then today I've had two camshaft codes come back
Post #404653 13th Sep 2016 6:01pm
