![]() | Home > Technical (L322) > Bleed valve |
ohuntsman Member Since: 21 Mar 2016 Location: Surrey Posts: 337 ![]() ![]() ![]() |
Like a chump I've over tightened the expansion tank bleed valve and sheared the head off, leaking coolant left right and Chelsea! We've ordered one on eBay but need a replacement before Saturday- does anyone know if BMW does a similar part? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8537 ![]() ![]() ![]() |
Use a suitably sized metal bolt with some PTFE tape, should hold a while... Pete
Cheers buddy- any ideas on dimensions |
No, sorry, measure it, probably an M6, M8 or M10, ie, 6,8 or 10 mm Pete
Ahh that would be sensible!
Sorted.... |
Any ideas what this leak may be?? It is on the passenger side of the oil sump |
Photos |
Photos |
Or this on the drivers side? It is a water leak incidentally.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3258 ![]() ![]() ![]() |
Air con condensate? John
Err well that would be incredible if they are- how would I know?? |
Weegie is spot on
Whoop thank you fellas!!
