Home > Maintenance & Mods (L322) > Front Diff/prop failure. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
LRCR is 0870 5000 500. Good luck. Only Range Rovers since 1988 |
6th Sep 2016 5:03pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Thanks mate 2003 Vogue 4.4 V8 Java Black |
6th Sep 2016 5:18pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8189 |
If you end up paying, use second hand bits off eBay... much much cheaper and if they are the modified ones (and I haven't seen an unmodified one yet) then they will be fine.... Pete
6th Sep 2016 5:42pm |
Do you think I need to worry about the mileage of the donor part or is it the coupling that is the only part that generally fails ? 2003 Vogue 4.4 V8 Java Black |
6th Sep 2016 6:54pm |
Get the lowest miles you can but don't worry too much, most places give a warranty and a mechanic should be able to check it before it's fitted... Pete
6th Sep 2016 7:55pm |
Called them, they searched my VIN and told me there's no outstanding recalls shown for my vehicle ? They didn't seem to know anything about a front diff recall at all (I thought it was a big issue??) . They asked me for a recall no. Or a service action request no. ?? I don't have either ???
7th Sep 2016 8:25am |
Also - as a credit to this forum - the JLR customer service asked for my VIN , once I gave it she types away --
7th Sep 2016 8:47am |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
You need to quote the Q041 Service Action from June 2008. Land Rover were careful to describe it as a “Loyalty Assurance Programme” and not a recall.
7th Sep 2016 11:59am |
I think the recall was in 2008, but there were failures before that which would have been repaired under warranty or at the owner's expense - yours was presumably a warranty job if the car was only a year old. The problem seemed to have been caused by misalignment and I believe the recall repairs incorporated a joint to make that less of an issue, perhaps in 2004 there was no additional joint and so your car remained vulnerable, even if it did last 12 years.
7th Sep 2016 12:14pm |
RRBlue Member Since: 23 Feb 2012 Location: Cambs Posts: 222 |
Were there any symptoms? I had a whining diff on my 2005 S/C for some time, then replaced it with a genuine new one which was much better but then it started whining. It was then replaced with another new one which now whines so loud, I can hardly hear fthe wireless. All within in a two year time frame. I changed the oil in the current diff yesterday. It was like Bisto and the drain plug had a thick coating of a silvery grey gunge.
9th Sep 2016 12:42pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
LR (Guy Salmon, Knutsford) replaced the front diff in my 2004 car in January 2012.
10th Sep 2016 1:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7793 |
Mine was done in Dec 2011 by the local dealer and I was told that it wouldn't be long before they wouldn't get any more authorised....on my TD6, obviously....
10th Sep 2016 1:12pm |
