![]() | Home > Technical (L322) > Front strut seal |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
So, have you replaced your airbag using your original strut?
franck siii Member Since: 08 Mar 2016 Location: clermont ferrand Posts: 3 ![]() ![]() ![]() |
Hi I only replace the airspring (air bag) and I keep the original shock absorber unit (gas damper). |
Hi I think the size of the big O'ring is OR 64x5 mm or 65x5 mm
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8539 ![]() ![]() ![]() |
Don't think you will find that info easily... most people change the entire strut in one go, if the bag is old and worn then the shock absorber will be very tired as well.... Pete
Never tried it myself... Not sure of the benefits apart from cost but as Pete said... Why as the shocker is still old |
