Home > Technical (L322) > Front strut seal
franck siii
France 2004 Range Rover HSE Td6 Zermatt Silver
Front strut seal
Hello everybody, excuse me for my English.
After remplacing the two front suspension air spring of my 04' L322 3.0 diesel, I got a problem :
The car lift well for 5 minutes but now I find a leak between the air spring and the shock absorber.
My air springs come from Aerosus.co.uk, all parts and seal looks good and the shock absorber are clean.
I have the same leak with the original seal, so I think it isn't a problem on shock absorber.
Do you know where I can found OEM seal (aerosus seal seems cheap)
I'd like to find quality O'ring which are a little bigger than original, so if someone had a solution for buying this....
Regards
Franck
Post #403027 2nd Sep 2016 10:31am
So, have you replaced your airbag using your original strut?
Or replaced the whole upright with new?
Post #403028 2nd Sep 2016 10:39am
franck siii
Hi I only replace the airspring (air bag) and I keep the original shock absorber unit (gas damper).
Post #403030 2nd Sep 2016 10:50am
franck siii
Hi I think the size of the big O'ring is OR 64x5 mm or 65x5 mm
If someone have the oem seal from the landrover Airspring kit
I want to know the size of the original new seal please.
Thank you
Post #403628 6th Sep 2016 12:00pm
Don't think you will find that info easily... most people change the entire strut in one go, if the bag is old and worn then the shock absorber will be very tired as well.... Pete
Post #403658 6th Sep 2016 1:59pm
Never tried it myself... Not sure of the benefits apart from cost but as Pete said... Why as the shocker is still old Confused
Post #403786 7th Sep 2016 12:25am
