Home > Technical (L322) > Alternator....power steering??!?
Harry1.2
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Barolo Black
Hi guys,
Hope your all well and enjoying your full fat rr!
I Bought mine last year with around 102k...drove like and absolute dream!
Recently I have encountered a few issues.
Last week my car wouldn’t start after 3 days or it parked, quick call to RAC, pleasant chap Andrew arrived... jumped the battery started absolutely fine, out with the multi-meter it was diagnosed with a dead alternator Sad
Bought an original from euro car parts: this was the part I bought
http://www.eurocarparts.com/ecp/c/Land+Rov...amp;000012
When I went to collect the car from an independent garage the car started fine but there was a slight off smell emitting from the vehicle...I thought nothing of it.. Drove it for around 20miles start and stop the engine around 7 times, no problems parked it up last night.
Started the car this evening with an awful sound that I can only describe as a high-pitched wail or spine-chilling screech, which lasted 10 seconds, also accompanied was smoke underneath the body with an odour.
Now the car has absolutely no power steering and i have the warning message on the dash "charging system fault"
When serviced by Land Rover 3 months ago there was an advisory of power steering leak.
Guys any help would be much appreciated, I am based in West Yorkshire
Many Thanks
Harry
2010 TDV8 Vogue SE
Post #401400 20th Aug 2016 10:49pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
The screeching noise will be the alternator belt slipping on one or more pulleys. This could have several causes:
– the belt tension could have been improperly adjusted;
– a battery that's low on charge will place extra demand on the alternator which makes it harder for it to turn;
– if that belt also goes round the power steering pulley you may have a problem there too.
– could be a duff bearing in the new alternator which has seized causing belt slip.
The lack of any power steering is harder (for me) to guess at. There are some very knowledgeable people on FFRR (unlike myself Rolling Eyes ) and I'm sure they'll be along soon to advise you.
In the meantime you could check your battery voltage with a multimeter and the fluid level in your power steering reservoir. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #401405 20th Aug 2016 11:23pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Check fluid level in the power steer reservoir a serpentine belt slipping on its own will not make smoke in the quantities you describe, you would smell it in an instance of very poor tension though.
Sounds like you have fluid leaking onto the system some place or a combination of these two problems.
Check belt tension you should barely be able to deflect it with your fingers.
The tensioner is a consumable part, it could be shot also
Is the belt fitted correctly, dont laugh it has a fairly complicated run.
There are actually two belts.
If you have sufficient fluid on the belts to make smoke as you describe I would be fitting two new ones......after the leak is fixed
Post #401410 21st Aug 2016 3:51am
p38arover
Australia
I'd check to see if the belt has snapped. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #401411 21st Aug 2016 6:45am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
That sounds like a snapped belt, I had the same problem.
I had the air con compressor changed then on the first proper drive I heard a screech, the power steering went very stiff and then the battery warning light came on. The belt had snapped Big Cry
Post #401427 21st Aug 2016 9:50am
johnboyairey
All my cars I've had, I always keep the old belt, when changed, (still good) in a box of other goodies in the boot, and a diagram, of how its routed. ( not obvious, if it's snapped) This can be fitted, by a breakdown guy, should the worst happen, on a journey.
The breakdown guy typically wouldn't have one to hand, so, it's a very handy thing to have for a rainy day. With a few other bits, like a few bulbs and torch, 12v pump etc.
Post #401463 21st Aug 2016 3:32pm
p38arover
Australia
I do the same, JB. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #401517 22nd Aug 2016 12:04am
Biker
Italy 2011 Range Rover Vogue TDV8 Santorini Black
If the belt is not snapped but doesn't turn around, it could be the pulley, at your mileage. They have something like rubber buffer to work silently, and they can Break.
Post #401873 24th Aug 2016 8:37pm
Biker
Post #401874 24th Aug 2016 8:41pm
