![]() | Home > Technical (L322) > Alternator....power steering??!? |
Harry1.2 Member Since: 20 Aug 2016 Location: leeds Posts: 2 ![]() ![]() ![]() |
Hi guys,
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Check fluid level in the power steer reservoir a serpentine belt slipping on its own will not make smoke in the quantities you describe, you would smell it in an instance of very poor tension though.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1543 ![]() ![]() |
I'd check to see if the belt has snapped. Ron B. VK2OTC
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
That sounds like a snapped belt, I had the same problem.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
All my cars I've had, I always keep the old belt, when changed, (still good) in a box of other goodies in the boot, and a diagram, of how its routed. ( not obvious, if it's snapped) This can be fitted, by a breakdown guy, should the worst happen, on a journey.
I do the same, JB. Ron B. VK2OTC
Biker Member Since: 20 Jul 2016 Location: Garda lake Posts: 9 ![]() ![]() ![]() |
If the belt is not snapped but doesn't turn around, it could be the pulley, at your mileage. They have something like rubber buffer to work silently, and they can Break. |
