![]() | Home > Technical (L322) > EAS , TR TC and more all off and won't reset. |
Help wanted
Thanks GreameS
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2578 ![]() ![]() ![]() |
Is there anything to indicate that the transfer case module is operating, eg that the high range LED is on or can you select low range? However it may not allow a range change if it can't see the speed messages on the canbus to know that the vehicle isn't travelling too fast.
Yes strangely the only thing Off Raod based that works is I can switch from high to low . 2008 MY Supercharged
OK, so the module isn't dead, not completely anyway.
You might try disconnecting the battery for 30 seconds if not already done. |
Thanks for you help , done a reset already , it's drivable so when I can move a bit I'll quizz Gap for pointers . 2008 MY Supercharged
Back to your first post, the refusal to clear will be because the fault condition still exists.
No I can't change heights. 2008 MY Supercharged
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
Transfer case ECU is behind the battery (well on the older models). Have a look, you should see a black plastic box, roughly the size of a box of Milk Tray (sorry, best I could do |
Considering the ecus listed with which contact has been lost, it's possible that canbus wires have been compromised. Loosing the TCCU gateway would not prevent TR from communicating with the suspension ecu or the rear diff ecu as they're all on the one side of the TCCU, with only the engine, ABS and gearbox on the other side.
Only a small child but thanks for the further insight and I'll investigate soon . 2008 MY Supercharged
These are the actual fault , the two for the rear differential have happened before so I am thinking ECU problem but where?
