Home > Technical (L405) > el. folding Rear seat not going to its end position anymore
abuss
Switzerland 2013 Range Rover Autobiography 5.0 SC V8 Firenze Red
Hi
since a few days one side (left) of the rear seats does not go back to its end position. It stops just short before getting there. The other side works perfect.
Any ideas?
Thanks, Alex
Post #398066 28th Jul 2016 3:18pm
The rear seats have a reclining option - I would guess that one side is set more upright than the other.
Open your rear door and set both seats to either fully reclined or fully upright & they should be level.
Post #398069 28th Jul 2016 3:28pm
abuss
I did this...but left seat stops before fully reclined. Question
Post #398070 28th Jul 2016 3:30pm
dfulgo
Italy
Seat belts are right in their proper resting places? 2016 RR ATB (Kaikoura Stone w/Brogue/Ivory-Brogue)
Post #398110 28th Jul 2016 6:09pm
abuss
yep all checked. Left seat stops before getting its end position.
Post #398503 31st Jul 2016 7:44am
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
Have you tried to remove the fuse and put it back in? ----------
2014 tdv6 (ex. 2004 td6, 1997 2.5 dse)
Post #398507 31st Jul 2016 8:45am
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Also try holding the recline switch for a longer period.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #398510 31st Jul 2016 8:53am
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi - Mine did the same. (2014 3.0 Autobiography)
All I did was to continually move the seat back and forward only half the way and the last time it went back to normal.
Fingers crossed.
Cheers
Post #398572 31st Jul 2016 7:45pm
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
Hello
cant fold my right back seat. the large one on the back left with the ski trap folds well back and forth
the rigth seat does not move with the command in the boot.
Also the seat buttons for inclination and position on the right of the right back seat does not produce anything but a click like a relay activating. also the command of seat folding in the boot does generate a small click.. same or different relay.
any ideas ? make me mad Smile 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #554894 22nd May 2020 3:55pm
karba78
just run diag on the FFRR looks like i have a pb B1 13a 00 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #554917 22nd May 2020 6:34pm
