![]() | Home > Technical (L322) > Why is the FF making a noise? |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 ![]() ![]() ![]() |
Needed to move the FF yesterday. From cold the engine was running for less than a minute as I moved it 10 feet then turned the engine off. I didnt lock it as I was going to clean the rear luggage compartment (calling it a boot seems a bit common for an FF). The car had been stood for about three minuets when I heard a noise (I was outside near the front off side wheel) that seemed to be a 'fan' type noise coming from the area of the scuttle and lasting about 15 seconds. I wouldn't have thought anything would have been on long enough to need cooling, but what else could the noise be? QUID FACIUM TIBI
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
ECU box under the bonnet has a fan to cool it, it will come on pretty often in this weather even without the engine on for long, it vents to the inside just above the brake pedal.... |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
My FBH will occasionally do this, sometimes without even starting the engine, just opening the bonnet seems to be enough encouragement!
Anybody know how to go about this, or disable it? Cheers. QUID FACIUM TIBI
Fuse 59, according to others on here and my handbook ('02), to disable.
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 ![]() ![]() ![]() |
No need to remove battery jo
