Home > Technical (L322) > Why is the FF making a noise?
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Needed to move the FF yesterday. From cold the engine was running for less than a minute as I moved it 10 feet then turned the engine off. I didnt lock it as I was going to clean the rear luggage compartment (calling it a boot seems a bit common for an FF). The car had been stood for about three minuets when I heard a noise (I was outside near the front off side wheel) that seemed to be a 'fan' type noise coming from the area of the scuttle and lasting about 15 seconds. I wouldn't have thought anything would have been on long enough to need cooling, but what else could the noise be? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #397650 25th Jul 2016 8:44pm
ECU box under the bonnet has a fan to cool it, it will come on pretty often in this weather even without the engine on for long, it vents to the inside just above the brake pedal.... Thumbs Up Pete
Post #397673 25th Jul 2016 10:52pm
My FBH will occasionally do this, sometimes without even starting the engine, just opening the bonnet seems to be enough encouragement!
(Note FBH been broken for years, either pump (what a stupid place to put it) or glowplug (too lazy to drain down / remove inner mudguard)) Embarassed .
Post #397676 25th Jul 2016 11:26pm
docjones
Finland
This issue is caused by FBH circuit board having blown it's caps. Any action that will wake up the car CAN bus will also wake the FBH which, due to the fault will start it's fan. The circuit board can be, and should be fixed. It can eat the battery and it will also disable the FBH.
DJ
Post #397705 26th Jul 2016 9:01am
Spelunker
Anybody know how to go about this, or disable it? Cheers. QUID FACIUM TIBI
ANTEQUAM ALIIS
Post #397980 27th Jul 2016 9:11pm
Fuse 59, according to others on here and my handbook ('02), to disable.
Removal is battery out, wheel off, inner wheel arch liner out, drain or clamp coolant pipes, remove FBH. Fix FBH Shocked , then refit in reverse order. There is a Rover 75 chap, French Mike, who repairs the circuit boards...
Thanks doclees for the info about the circuit board. Not been causing any battery problems here though... .
Post #397983 27th Jul 2016 9:53pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
No need to remove battery jo
Get to it all under wheel arch Thumbs Up
Post #397989 28th Jul 2016 2:43am
