Home > Technical (L322) > reduced performance
Page 2 of 3 <123>
Terrier
Thanks Alistair.
It's like a lottery isn't it. Oddly looking forward to finding out what it is now. That sensation won't last long I'm sure!
Post #396663 18th Jul 2016 7:36pm
There is a turbo blend valve type thingamy which has been known to fail. There is an updated part.
I think that the problem is that the secondary turbo is rarely used on some cars so the valve which activates it does not come into play too often and sticks.
I will try and find the thread. There is nothing that can't be fixed with a hammer😜😜
Post #396675 18th Jul 2016 9:07pm
This thread ?
Post #396677 18th Jul 2016 9:12pm
This one
http://www.fullfatrr.com/forum/topic37268....dary+turbo
Edit Alistair beat me to it.👍 There is nothing that can't be fixed with a hammer😜😜
Post #396678 18th Jul 2016 9:13pm
n1cktdv8
Gents...OP states 2011 TDV8 in his original text Whistle Is this where I put the car details and a bit about myself ?........
Post #396680 18th Jul 2016 9:31pm
Rolling with laughter Need to learn to read properly Embarassed
Post #396683 18th Jul 2016 9:36pm
True enough, though I thought there may be a few 3.6s out there on 11 plates..... In any case the link to the thread above describes one possibility Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #396685 18th Jul 2016 9:46pm
Baltic Blue
I posted a thread called 4.4tdv8 restricted performance some time ago, which describes exactly the same symptoms.
I have got a copy of the service bulletin if required.
How do I add a link to the post?
Post #396696 19th Jul 2016 7:22am
Terrier
I think I've got a link to it above Baltic thanks.
I'll speak to the Indy this morning and get her in. Shame though, as she's been faultless in the 9 months I've owned her.
Given your sign in, can you remember what in November 1987?
Thanks mate.
Post #396698 19th Jul 2016 7:31am
Baltic Blue
Get the 4 short turbo inlet hoses checked at the same time.
One had split on mine.
Sorry don't understand the question re November 1987 ?
Post #396701 19th Jul 2016 7:53am
Terrier
Apologies, I missed the word happened out of my sentence.
I took it you were a city fan given your sign in. If you are I'm sure the clue "triple hatrick" shall give it away!
If not, I'm looking a bit daft!
Post #396718 19th Jul 2016 9:53am
Baltic Blue
Sorry, far too cryptic for my simple brain.
Baltic blue is the colour of my car.
Post #396719 19th Jul 2016 10:01am
Terrier
Doh, clearly I know more about football than full fats.
Anyhow, Indy thinks it's EGR Valve, if I've remembered it correctly.
Post #396761 19th Jul 2016 5:19pm
Terrier
Just to update, it's believed to be a split hose, one of the 4 hoses which run in an around the turbo. I'm having all four replaced whilst they're under the bonnet, £240 + VAT.
Thanks for all the responses, a cracking forum this one Thumbs Up
Post #396867 20th Jul 2016 3:53pm
MartSim73
Hi Terrier.... Can I make a further suggestion to save further cash and worry down the road?... I too have a my11 4.4tdv8. I had split hoses and had them replaced. I also had DPF failure due to the crud and oil based around the same problem. However, having sorted all that back in January, the car was a little hesitant, not knowing whether to go up a gear or down when you wanted or needed to plant your foot.... Well, that's how it felt.
....get to the point. At the beginning of July it finally went into performance reduction mode and just as I was taking it to the garage the engine management light also came on 😱. Well, I thought it was turbo issues! Wrong! It was part of the original split hose problem! They had cleaned and replaced parts backward from the problem, but not forward of it! Now, I'm not sure which sensor it was, but in the inlet manifold you have some sensors. Mine were covered in crud and this had not been previously checked. The sensor(s) didn't know how much fuel to put in so being gunked up, misread pressures/fuel required etc (ask an expert here.... Not my thing really). Now, as it's been cleaned out properly, my L322 drives like a dream! Would be worth getting them to check any sensors around this area are re cleaned too. Thumbs Up
Post #397016 21st Jul 2016 4:40pm
Page 2 of 3 <123>
