Home > Wheels & Tyres > Supercharged, can i go 19 inch or 18 inch for offload tires?
RR-EVO
France 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Some says it doesn't fit because of the Brembo calipers but i bet that they never tried.
I can slightly cut the disk protection.
Post #394329 4th Jul 2016 6:06am
CS
Style 15 19" wheels work with brembo calipers, at least on my 2012 car, I use Goodyear Duratrac 255/55 R19 as my winter tyres and have been happy with them. I'm not sure whether the same wheel nuts would work. There is not much clearance between the caliper and the wheel, so if you drive on very gravelly ground you might get the occasional scoring on the wheel. It has not been a problem for me so far. Only Range Rovers since 1988
Post #394358 4th Jul 2016 11:45am
mzplcg
Yours has 4 pot Brembo calipers which were standard on all L322s from 2005 to 2009. These will be fine with any standard 19" wheels or the special 18" from Compomotive. Search for posts on this - I think the user was TheAllSeeingPie.
It's only the 2010 onwards 6 pot Brembos that will generally only fit behind a 20" rim. The style 15 which is a 19" wheel as noted above is the one exception for a 2010 onwards car.
Post #394369 4th Jul 2016 12:45pm
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
2008 SC on Compomotive 18s here. The car's also had a facelift, but that's only cosmetic ... Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #394380 4th Jul 2016 1:22pm
