![]() | Home > Wheels & Tyres > Supercharged, can i go 19 inch or 18 inch for offload tires? |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1396 ![]() ![]() ![]() |
Style 15 19" wheels work with brembo calipers, at least on my 2012 car, I use Goodyear Duratrac 255/55 R19 as my winter tyres and have been happy with them. I'm not sure whether the same wheel nuts would work. There is not much clearance between the caliper and the wheel, so if you drive on very gravelly ground you might get the occasional scoring on the wheel. It has not been a problem for me so far. Only Range Rovers since 1988 |
Yours has 4 pot Brembo calipers which were standard on all L322s from 2005 to 2009. These will be fine with any standard 19" wheels or the special 18" from Compomotive. Search for posts on this - I think the user was TheAllSeeingPie.
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 190 ![]() ![]() ![]() |
2008 SC on Compomotive 18s here. The car's also had a facelift, but that's only cosmetic ... Regards,
