Home > Technical (L322) > Iid bt tool how to disable tpms?
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Hi
I have a 2007 sc ,i have bought a iid bt tool, how do i disable/ turn off tpms ?
Can somene point me in the right direction, how to use the iid bt tool?
Thanks 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #392723 22nd Jun 2016 11:18pm
theres a link to the iidtool user manual in the wiki or you can download from the GAP site.. ... - .- -.
Post #392731 23rd Jun 2016 6:28am
STEVE57
Looked at the user manual on wikki
But no mention of tpms ?
Do i need to look in ccf files , how do i dissable tpms
Has anyone done this ? 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #392735 23rd Jun 2016 7:42am
https://www.gap-diagnostic.com/wordpress/w...lV3.00.pdf
Page 80 onwards.
And yes, many people have done this, including me Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #392742 23rd Jun 2016 8:54am
jambo27
Hi
I know when I first tried to do this on mine I had an issue finding the correct menu in the CCF section. Unfortunatley I am not with my car or IID tool at the moment so I can't tell you the precise steps but IIRC there was an option on the IID to rescan ECU (not in the fault section I think in some config menu). Once I did this I went from having about 6 options in the CCF section to loads more and low and behold one was the heading TPMS.
I am back with the car tomorrow so I will plug in the tool and try and confrim exactly what steps I took. 2008 TDV8
Post #392757 23rd Jun 2016 10:53am
its very easy, in the ccf look for tpm-tire pressure monitor and select off.. ... - .- -.
Post #392758 23rd Jun 2016 11:08am
PatGAPInnov
Site Sponsor
Canada 2010 Range Rover Autobiography 5.0 SC V8 Causeway Grey
For a 2007 RR, Menu->Car Config->TPMS Tyre Pressure Monitor, set to Not Fitted / None
Remove Fuse 6 in the central junction box (passenger glove box) http://www.gap-diagnostic.com/
Post #392770 23rd Jun 2016 1:08pm
STEVE57
jambo27 wrote:
If you can check and tell me the steps that would be useful,
Thanks
fb 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #392838 23rd Jun 2016 10:21pm
STEVE57
Hi
Used the iid tool now tpms turned off,
Thanks
Everyone 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #393361 27th Jun 2016 10:02pm
Well done that man!
It's such a relief to not worry about any false alarms any more and you can replace the chocolate valves with proper ones! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #393363 27th Jun 2016 10:07pm
